B-Fast B-Strong William Smith (144 posts) Registered: 10/17/2009 11:28PM Main British Car: Bugeye Bodied Spriget |
Question About Steering changes on V8 Swap !
I am trying to get all the info I need to swap a Ford 302 into my RB roadster. Ordered a Williams book but I got a copy that covered only the alum v8 with right hand steering. Looking at pictures in your photo gallery, after cutting the firewall out, putting the metal back and re-cutting the hole it looks to me like the steering column does not stick through as far as it did. Has it been shortened? Do mods need to be made ? If so what !!!!!
Thanks Will |
Re: Question About Steering changes on V8 Swap !
Will, looks like this post is from back in early Nov... if you're still looking to figure this out, reply with what you're doing for motor mounts. If you're using Comet mounts like Graham, Pete & others, you shouldn't need to modify the firewall or change the steering. If you're using the FastCars front suspension with integral 302 mounts or fabbing your own mounts & putting the engine lower/further back like the FastCars suspension does, then you'll need to modify the firewall. Neither of those should require you to modify the steering column mount point.
