Which brakes?
So, I'm going to upgrade the brakes on my Tiger. I have seen some upgrades for other English cars, I figure a Tiger should be the same as any other old English Auto. I've read about Toyota 4x4, Volvo 240's and some from a Rover, I would like to stay with Girling, but the conversion that is the simplist will win. I know there are Wilwood, and other hi-tech, hi dollar conversions out there, but Im looking for a more modest set-up. Does anybody have experence with the Toyotas, or Volvo's calipers?
Re: Which brakes?
I know the volvo are 4 piston and will require some work as they have 2 hydraulic lines, but they are relatively cheap to get from a junk yard(if you can find them). just fabricating a bracket may be your challenge. I have been considering volvo brakes on my alpine to tiger conversion, but have not reached that stage of the project yet. good luck
fasttiger Jerry Porsch Las Cruces, New Mexico (78 posts) Registered: 10/23/2007 08:40AM Main British Car: 1966 Sunbeam Ford 380 ci with twin turbo's |
Re: Which brakes?
I went with Areo Space on the front of my Tiger took some work, but I was lucky i had the use of my sponsers machine shop to bore out the hubs to fit the bearings and also I had to make my own brackets. They work great, but took some work to get them on.
I also did the rear with disk that come from a must. but then again took some machining and had to make my own brackets. I don't know of any just simple ways to redo brakes on a Tiger. |
