jim0899 James Willenbrink Florence, KY (60 posts) Registered: 10/05/2010 04:46PM Main British Car: 1978 MGB Chevrolet 327 |
Replacing steering rack boots on MGB
One of my Winter projects is to replace the steering rack boots on my 1978 MGB. I found the following on the Moss Motors site, in the tech tip library, and I was wondering if anyone had used this technique to replace the boots. If it works, it looks like it could be a huge time saver, especially if you don't intend to replace the tie rod ends.
(Quote)--- MGB GT Rack Seal Tip I recently changed the steering rack boots on my MGB GT. I read the tech in the Moss Motors' Parts Catalogue and followed the steps with one exception. I did not remove the tie rod ends. Instead I rotated (unscrewed and counted turns) the tie rod from the tie rod end, where there was ample room, as the wheel could be pivoted about the king pin exposing the boots. Assembly was just the reverse. This procedure saved tie rod end removal and potential damage to the tie rod ends. It probably saved me at least one hour and I did not need any special tools, especially a big hammer. (We have found that accurate reassembly is made easier by first cleaning the exposed tie rod threads, and then spray-painting them. This leaves a definite reassembly reference, and is more accurate and reliable than counting and remembering turns.-Ed.) George E. Blumb Noblesville, IN |
Re: Replacing steering rack boots on MGB
I've done it that way and it works well. In addition to the spray paint idea, you can use a sharpie marker to put an index mark which will allow you to go back to exactly the same alignment.
JB |
Thanks Jim,
I like the idea of using a sharpie in addition to the paint, that should keep your alignment exactly the same. |
