Stag Rear Disc Brake Conversion
Hi. Has anyone out there had any luck manufacturing or copying a " rear disc brake conversion " for a stag? If you have could you please publish details and we can compare details with my conversion.
Re: Stag Rear Disc Brake Conversion
Staggered, there are a number of Stags running around in the UK with an E30 BMW 3-series rear end... I presume this includes disc brakes.
I understand the Ford Sierra set up is quite a popular conversion on the Stag but to be honest I think it looks a bit
of an afterthought. My first choice was an early Datsun 280ZX with 4 stud wheels, the diff, drive shafts and brakes all look fairly easy to adapt to the Stag. The whole rear end layout on the early Datsun 160/180Bs were more or less a copy of the Triumph 2000/Stag layout which were later used on the Z cars. |
Sparrow010 Andrew Gaskin New Zealand (19 posts) Registered: 06/06/2009 08:04PM Main British Car: 1974 Triumph Stag Toyota 1 - UZ - FE Quad cam 4.0 |
I used a kit from monarch stags in the UK.
Its a ford set up. works nice with their BMW servo up grade. |
