71lexenza
Jason Huskinson
(4 posts)
06/04/2012 03:39AM
Modified steering rack
Posted by: 71lexenza
Date: June 04, 2012 03:59AM
Gents, i have a problem with my project (1uzfe into a 1971 firenza) i have had to move the steering rack forward by 70mm to allow the engine to sit in its final resting place. I dont have the front suspension assembled yet but i am guessing the rack arms will now not reach the steering arms.
I was thinking of extending them but i think the extention piece will also need to be bent to allow them to operate as originally designed.
Has anybody done this?
Will it effect steering geometry?
Cheers Jason
Bill Young
Bill Young
Kansas City, MO
(1337 posts)
10/23/2007 09:23AM
Re: Modified steering rack
Posted by: Bill Young
Date: June 04, 2012 08:52AM
Yes, it will affect geometry, but mostly bump steer. The main problem will be to make sure that the tires don't rub on the steering links at full lock with that much movement. Bending the arms really won't help anything, the action is still the same as a straight rod but it may gain you some clearance with the tires but at the cost of limiting the adjustment a bit. Instead of moving the rack forward can you move it down a bit? That's what Jim Blackwood did on the Roadmaster and his MGB for clearance and it worked fine with the steering arms flipped side for side. Curtis has a good article posted that has some good shots of thy front suspension.
71lexenza
Jason Huskinson
(4 posts)
06/04/2012 03:39AM
Date: June 04, 2012 04:14PM
Ok, i will have a look at moving it down.
I had another thought, i could off set it by about 0.75" to the drivers side but keep it in the original mounting plane. I could play about with track rod ends to take out the offset, what do you think??
Date: June 04, 2012 04:52PM
If playing with the track rod ends means simply extending one and shortening the other, than I think it's a bad idea. All cars have some roll steer, but your roll steer would be asymmetrical and that would make your car's handling very peculiar. However, if you mean shortening one side of the rack assembly and lengthening the other - inboard of the inner swivels - then I think it's a splendid idea.
71lexenza
Jason Huskinson
(4 posts)
06/04/2012 03:39AM
Date: June 05, 2012 01:47AM
Late last night thought of another idea! If i make my own brackets to clamp the centre section of the rack, i can keep the rack in the original position, i can then rotate the rack by about 15° and then the input shaft will clear the block, That way it should not effect the geometry!! Will let you know how i get on!!
Bill Young
Bill Young
Kansas City, MO
(1337 posts)
10/23/2007 09:23AM
Date: June 05, 2012 08:18AM
That is very similar to what Jim Blackwood did on the Roadmaster, used split shaft collars to mount the rack so that he could drop it and rotate it as well. Take a look at the photos, you'll see very clearly how he did it.
