DIY aligment / squaring rig?
Not sure if this is the right section to post - if not please move it!
I have a '79 MGB - I finally got to drive it toward the end of school. Besides scaring the living hell out of me I also realized I do not have the four corners completely square. Early in the project I had the car at a repuatable frame shop and it was squared off. However later down the line while lowering/installing some new parts in the rear I cut down the existing front spring perches. I believe even though I measured a dozen times I have something slightly off - It was able to feel it accelerating and especially under hard braking(back end kicked out). Does anyone have a DIY alignment/squaring rig they can suggest for all four wheels? I've tried measuring front wheel center to rear wheel center on both sides - one side is dead on to spec - other isn't. Also tried just using a measuring tape but usually requires a friend and isn't dead on accurate. If anyone can recommend something or even has pictures of their rig I'd greatly appreciate it. Due to college loans trying to avoid taking it back to a shop. Thanks for the help. |
Re: DIY aligment / squaring rig?
Are you sure your brake bias is set right? Sounds like the rears are locking up before the fronts. Did you change front or rear brakes?
Rebuilt both ends - Thats what I thought originally after the first test drive. However I remembered that it felt slightly off taking off/under moderate acceleration(didn't get on the fun pedal much). The only other reason besides that I have to believe its the frame alignment is measurents I took(one side 'longer') - and the limited slip is always locked , leading me to believe its caused by the rear end not being sqaured up.
Robert, I suggest veiwing Jim Stabe's MGB build. He used a creative and easy to build alignment jig. Of course someone can follow behind your car, attempting to go straight, while checking for "crab" effect. As a crude check, you might center the front wheels, and pull a string front to rear, on both sides. Good Luck, roverman.
In principle, basic four wheel alignment is entirely "do-able" with four jackstands, two pieces of string, and a tape measure. Perhaps this photo (from BritishV8 2009) will help:
(In this case, the car's front track is narrower than its rear track, so the string is just wrapped around the rear tires... only two jackstands were needed in this case.) For best accuracy, it's important to get the car level first. (If your floor isn't level, use shims under your tires.) Since I usually work alone, and since I can't hook a tape measure over a string without causing deflection, I find it helpful to put masking tape on the floor in a few strategic spots and then use a plumb-bob and a pen... basically getting from a 3-dimensional world to a 2-dimensional one that's easier to measure. Actually, I don't use actual use string at all anymore. I have a nice, stiff, straight aluminum extrusion that's far handier. I have a mark on it at mid-point that I align with the holes in the MGB hub bearing covers. A longitudinal groove in the extrusion is a convenient feature - my plumb-bob's string fits neatly in it. Once I have two marks on the floor for each tire, I can measure side-to-side to get toe-in. The extrusions extend out to twice the diameter of my tires. (So by my method, a measurement of 1/8" of toe-in on the floor equates to 1/16" of toe-in on the car. Comprehend?) I can also snap a chalk line to extrapolate from one end of the car to the other, to verify that the front and rear are in alignment with each other. |
If you have a chalkline you can strike a line on the floor.
First thing I'd recommend is to tighten the U bolts holding the rear axle to the springs. Loose U bolts can cause the rear axle to move forwards and backwards under brakeing and acceleration resulting in some pretty dramatic torque steer. Crank them down as tight as you can with a standard 1/2 inch drive ratchet and see what it feels like then.
Thank you for your replies - I greatly appreciate it.
The U-bolts are the last thing I checked and the only culprit I can think of causing the situation with everything else considered. My procedure thus far as been to measure both sides front center line to rear center line - One side is spot on at 91" which is what my fathers MBG measures at and also what I've read is the correct length. One side is side is at 91" ; The other side was about 1"+ off when I measured after the test drive. I removed the traction bars and realized bar had been "pushing" the incorrect side back. After I removed both I was still 3/4" off. I've tried matching both rear shackle angles and boring out the front mount to slide the spring foward - its still off. After fighting with it I took a break from it. Hopefully its something very minor(possibly the u-bolts) I'm missing and I'll have it corrected soon. Otherwise its back to the frame shop. Thanks again guys. |
You can fit heavier u bolts for better clamping force. Just drill out the plates a little. Makes a big difference.
Robert, Both springs have same arch, length and no broken leaves ? Good Luck, roverman.
