Steering
I'm making a couple of slight changes to my steering shaft and in the process found a little play in one of my outer rod ends. I tried the fork method with no success and my next step is to try a little heat on it. Is this a good idea or not? I'm changing both of them and the boots while I'm at it. I also want to replace the oil in it too but I've never done that; recommendations would be greatly appreciated.
Paul |
Re: Steering
Hey Paul,
No heat! Bad things happen to good steering parts when you heat them. The pickle fork should work, you just need to line it up so that the force vector lines up with the steering arm. The idea is to provide a "backing" for the pickle fork to hammer into. The down side to this device is that the joint is almost always destroyed in the removal process. The best way is with a proper puller. Something like this won't tear the boot or damage the joint. There is also the two hammer method, but the chance of damage to the steering arm is very high. So we'll just file that one away with the heat idea. Your steering rack contained gear oil when new. It holds 1/2 pints and is filled with a small nozzle through one of the boots with the clamp loosened off. I personally prefer to use moly grease. It has better lubricity and more "sticktion" so it won't all leak out through a split boot. Just drill and tap the plate for the rack slipper and add a grease nipple. You can now maintain your rack at will. Hope that's helpfull Fred |
Re: Steering
Thanks Jim, I tried the hammer method too; maybe I'm too old and weak to hit it hard enough.
Thanks Fred, Summit has the removal tool you recommended, and I promise, no heat.. Paul Edited 1 time(s). Last edit at 05/21/2014 08:40PM by pspeaks. |
Re: Steering
That removal tool is the way to go and you can borrow them from your local parts house. But if (when) you resort to the hammer method, here's the scoop: What you are doing is *slightly* and *temporarily* deforming the taper socket so that it loses its grip on the taper pin. As a forged piece this should not do any long term damage to the socket, but is very likely to produce dents on the outside of it. To do that most effectively takes two large hammers of about two pound weight, as big as you can effectively swing in the allowed space and hit your target smartly. There are two methods. You can use one as a "backer" much like you use a dolly when doing body work, to increase the mass of the knuckle and make the blow more effective and swing the other smartly into contact directly opposite across the socket. In this case the backer should be as large and heavy as it can be and still fit and be held snugly in place. The other method is to swing both hammers into contact simultaneously, but obviously this requires greater skill and coordination. The advantage is that considerably lighter hammers can do the trick.
Using a single hammer is both singularly ineffective and much more likely to damage the steering knuckle, But in a pinch it often can be made to work. Jim |
Re: Steering
Hey guys, I decided to try the "pickle fork" one more time and it worked; yes it messed the rubber on the rod ends up a bit, but they're 42 years old and I'm replacing them anyway. Now I've got my steering rack out so I can set in front of the flat screen in the garage, smoke a cigar (don't hate me), watch "Wheeler Dealers" and get my steering redone. As I already have them, I'm also changing my calipers, disks and wheel bearings while I'm at it; got to get all them parts out of their boxes. Fred, I'm taking your advice and installing a grease fitting. Thanks for all the info, you guys are the best.
Paul Edited 3 time(s). Last edit at 05/24/2014 08:26PM by pspeaks. |
Re: Steering
An after thought here. Does using moly grease cause the steering to be a little stiff in cold weather or is it enough to be noticeable?
Paul |
Re: Steering
I'm from Canada Paul.
Define "cold". |
Re: Steering
It's only 64 today, but admittedly it gets 107 here in Dallas during the summer. To make up for that heat it can get around 16 for days at a time in the winter. I had a 65 Mustang with a four speed which would get a bit hard to shift in the winter. I was just curious but if it's not a problem for you in Canada, it shouldn't be a problem for me here.
Paul Edited 1 time(s). Last edit at 06/09/2014 01:59PM by pspeaks. |
Re: Steering
I've tried to order tie rod ends from Victoria British and Moss but both have been out of stock for some time. Does anyone know if there is a match I can get from a parts store?
Paul |
Re: Steering
Worldpac. Part # QR1153
On McEwen road downtown Dallas. |
