MadMarx Christian Marx Germany (54 posts) Registered: 01/02/2014 11:54AM Main British Car: 1977 Triumph IMSA TR8 Group 44 Canada Rover 4L |
Rear spring rates - IMSA TR8
Hello to all and a happy new year.
I have bought the canadian Group 44 car last year and did some racing with it. It becomes more and more evident that the car has trouble on the rear end. On down shifts it likes to lock the wheels which makes it quite nerveous. The engine brakes down the car a lot and with additionally aply of the brakes this locking comes in. After careful measurement it seems that the rear springs are stiff with 310lb and second is, because of the stiff spring there is almost no rebound travelway, just an inch then the wheels are off the ground. What do TR8 racers use on the rear coil over type as a spring? Cheers Chris Edited 1 time(s). Last edit at 01/01/2015 04:39PM by MadMarx. |
Re: Rear spring rates - IMSA TR8
So YOUR the proud owner ! Congratulations ! I have a Huffaker TR8 GT1, so rear rate should be similar. AIR, my rear is 250 lb/in ? I shall check. My car has a 3 bar set-up, with tunable IC., on single upper bar. I pulled the non-adjustable Carreras off, and went with double adjustable, QA1's. Good Luck. roverman.
My general rule of thumb was to go as low and soft as I could without letting the rear bottoming out.(175# to 300# on a 2600# TR8 with driver) Keeping the rear wheels on the ground on a bumpy track was always an issue. The softer I went in the rear, the stiffer the sway bar needed to be front and rear to keep the car from leaning.
Yes, I'm the proud new owner. Was a really surprise when the car was offered to me.
The engine sounds so sweet. I'm thinking about to go down from the 310 lb to a 220 lb rear spring. And making the travelway a bit longer. I did soften the car on the front also. Going down from 600 to 500 which cured the understeer. The rear axle is located by a 4 rod system and a z-bar. Seems to work pretty well. Sway bars at front and rear. 28mm on front. The rear one I don't know....maybe 19mm. I'm also not sorted out the tire question: Radial or bias ply. Radials are hard to get in Europe and sold for gold. Bias plys from USA are reasonable priced. For the moment it seems the radials are faster but that is maybe a setup issue. |
Great car! I think your guess at 220 would be good. Most like 200-250 for rear coil overs. Look at Tire Rack for specs on American Track tires.
Very good I'm on the right trail with the 220 rate springs.
I think the car is too light to use heavier springs. Cheers Chris |
