exfed12825 Tony Gentile Waterford, Pa (61 posts) Registered: 03/30/2016 02:43PM Main British Car: 1974 MGB 347ci Bessel Motorsports/ Ford stroker 530 hp |
Fluid Film
I'm planning on using Fluid Film on the Heim Joints on my Fast Cars inc MGB suspension any better choices for the lube
Re: Fluid Film
Fluid film will work just fine.
You will need to apply it often as it's a little thin and tends to be pushed out of the joint. I generally use moly chain lube in this situation. It's a heavy grease in a solvent carrier. It sprays on thin and works it's way into the joint, the solvent evaporates leaving a very durable moly grease film behind. It works well in lots of other applications as well, door hinges are my favorite! The best way however, in my mind, is to seal the joints with urethane cups. I think Prothane makes them if I remember right. And drill them to take a grease fitting. This keeps the dirt out and alows you to flush the joint with fresh grease from the inside out. Live like you mean it. Fred |
Re: Fluid Film
Fred, you have a link? I couldn't find those on their site.
Re: Fluid Film
I put some on my Milano a while ago.
Pretty sure that there is a part # on them. I'll jack it up on monday and have a look. Cheers Fred |
Re: Fluid Film
Re: Fluid Film
They sort of do. Easy for them to get damaged or in a position where they do not seal though.
Re: Fluid Film
Got a look this morning
The number on the seals is 60461 From Prothane for sure. Cheers Fred |
Re: Fluid Film
