TR6-6SPD
Ken Hiebert
Toronto Ontario
(255 posts)
04/23/2008 11:43AM
1972 TR6 1994 5.7 L GM LT1
Electric Power Steering on a GM Tilt Column
Posted by: TR6-6SPD
Date: May 02, 2016 10:59AM
Installing electric power steering in my Triumph TR6 made sense since parking it with the 245/45/17” front tires made it a bear to turn. What complicated my installation was the fact that I am using the GM tilt column from a Pontiac Fiero. Although it is just about the shortest tilt column you will find, the end of it still extends into the engine compartment, putting the EPS unit outside the interior space. The complication arises because the ignition and high-beam switches are mounted on the outside of the column, down low, and I did not want to disturb them.
A search on Google brought me to a well described EPS installation in a Pontiac Fiero. Perfect for me. This also went through the whole assembly process of the column itself. Included was a link to learning all you ever wanted to know about your tilt column.
EPS install in a 1986 Fiero GT:
[www.fiero.nl]
Inside GM Tilt Column:
[www.fiero.nl]
The most challenging part of my installation was attaching the EPS unit to the bottom of the column when they are on either side of the firewall. Hopefully I won’t have to remove it any time soon. Providing torque supports for the EPS unit was important.
Fabrication
After determining the placement of the EPS, I trimmed the GM column housing down to the needed length. I fabricated an adaptor sleeve to go between the salvaged EPS mounting base and the now cut column. After clocking it for correct orientation, the base was welded on.
With that length set, I assembled the inner shaft using the salvaged EPS female spline and adaptor tube, fabricated on a lathe to go between that spline and the tilt column ¾” D shaft. The Fiero website describes 3 different variations of this adaptation.
After trimming the EPS of unnecessary brackets, it was cleaned and painted. To provide torque support for it, I fabricated a pedestal to attach at the motor and an L bracket at the gear box end. Some re-working of the pedal box area of the TR6 was necessary.
Electrics
I salvaged the original Saturn Vue 30 Amp fuse holder which was mounted on the firewall. The potentiometer was mounted next to my headlight switch, below the dash. The controller box and Bruno box were mounted under the dash on the passenger side. This meant I had to extend the OEM wires that go between the motor and the controller box. Otherwise, the wiring was pretty straight forward as with all other EPS installations.
Steering Shaft
With a different output spline from what the original column had, I had to fabricate a new shaft. More lathe and welding work.
Do I like it? You bet I do. Not only is parking is a breeze, working the tight switch back turns in the Appalachian Mountains is so much more enjoyable. I find the potentiometer is a set and forget affair. I may wire in a switched circuit that has a pre-set resistor of my choice.
EPS mounting base, adapter sleeve + column housing:
EPS female spline and fabricated adapter tube:
TR6-6SPD
Ken Hiebert
Toronto Ontario
(255 posts)
04/23/2008 11:43AM
Re: Electric Power Steering on a GM Tilt Column
Posted by: TR6-6SPD
Date: May 02, 2016 11:02AM
Assembled inner steering shaft:
Pre-assembly column components:
Assembled GM Tilt Column with EPS:
TR6-6SPD
Ken Hiebert
Toronto Ontario
(255 posts)
04/23/2008 11:43AM
Posted by: TR6-6SPD
Date: May 02, 2016 11:05AM
Main components:
Potentiometer:
Controller and Bruno box:
Finished Electric Power Steering:
kstevusa
kelly stevenson
Southern Middle Tennessee
(985 posts)
10/25/2007 09:37AM
Posted by: kstevusa
Date: May 02, 2016 12:38PM
Nice Job Ken, "slick as as a Babys's Butt". The Dragon Beacons!
Date: May 02, 2016 12:57PM
Very nice work Ken. You've gotten really good at this sort of thing.
Jim Stabe
Jim Stabe
San Diego, Ca
(829 posts)
02/28/2009 10:01AM
Posted by: Jim Stabe
Date: May 02, 2016 03:59PM
Nice work on the EPS. How about an update on your Jag journal... Should be just about finished by now.
TR6-6SPD
Ken Hiebert
Toronto Ontario
(255 posts)
04/23/2008 11:43AM
Posted by: TR6-6SPD
Date: May 03, 2016 08:06AM
Jim Stabe,
The next update on my Jag Journal will probably be the EPS installation.
Ken
Charles
Charles Long
McDonald, TN
(177 posts)
09/15/2013 08:54AM
1966 MGB V6 1994 Camaro 3.4L 60V6
Posted by: Charles
Date: May 04, 2016 09:26PM
Ken, welcome to the darker side. Both of you guys will be amazed at how much better the driving is.
One of my car friends down in GA. has installed a EPS in his Fiero, the one with a Cady engine.
See you in Townsend shortly.
charles
I see you have GM cruise also. Question what is the set point for cruise?
TR6-6SPD
Ken Hiebert
Toronto Ontario
(255 posts)
04/23/2008 11:43AM
Posted by: TR6-6SPD
Date: May 05, 2016 12:35PM
Charles,
What do you mean by set point?
The cruise control in my TR6 is all OEM GM stuff controlled from the steering column stalk.
Ken
Charles
Charles Long
McDonald, TN
(177 posts)
09/15/2013 08:54AM
Posted by: Charles
Date: May 05, 2016 08:39PM
Ken, I forgot to mention how nice the install looks, but what can one say, your work is always top notch.
Guess what, now you guys will be able to one hand through the auto crosses, maybe cut time a few seconds.
You may need a three way switch, driving, parking, then auto cross.
Set point, is the minimum speed at which you can you set cruise?
Date: May 05, 2016 09:23PM
I think a set point of 25 mph would be good. For school zones.
TR6-6SPD
Ken Hiebert
Toronto Ontario
(255 posts)
04/23/2008 11:43AM
Posted by: TR6-6SPD
Date: May 06, 2016 05:25PM
Jim,
I do in fact use the cruise for that, (25 mph school zone).
Ken
Charles
Charles Long
McDonald, TN
(177 posts)
09/15/2013 08:54AM
Posted by: Charles
Date: May 14, 2016 07:27PM
Got to see this install first hand in Townsend, Tn, "Over the top" clearly a lot of thought and planning.
Well done, enjoy.
Good to see You and Katie again.
charles
Khan
Khan Caesar
(4 posts)
08/04/2016 04:57AM
Posted by: Khan
Date: August 07, 2016 10:30AM
Great Job, How about the calibration?
TR6-6SPD
Ken Hiebert
Toronto Ontario
(255 posts)
04/23/2008 11:43AM
Posted by: TR6-6SPD
Date: August 08, 2016 09:37AM
Khan,
By calibration, do you mean the potentiometer setting?
Quote:
"I find the potentiometer is a set and forget affair. I may wire in a switched circuit that has a pre-set resistor of my choice".
Right now, the pot is set at about 2/3 rds.
Ken
(1365 posts)
Date: August 12, 2016 03:36AM
Done a bunch of the EPS conversions now. (17 and counting) I don't ever think that I will even consider a hydraulic system again!
At one point I considered a variable assist circuit based on vehicle speed. To a person, all of my customers said that it wasn't required.
Everyone had found a sweetspot on the adjustment and left it there.
Live like you mean it.
Edited 1 time(s). Last edit at 08/12/2016 12:40PM by DiDueColpi.
zapskate
Conner Westra
(2 posts)
08/19/2016 07:25PM
Posted by: zapskate
Date: August 20, 2016 07:03PM
Hey, where did you get the pot and Bruno box and do you have a wiring diagram for the electronics?
TR6-6SPD
Ken Hiebert
Toronto Ontario
(255 posts)
04/23/2008 11:43AM
Posted by: TR6-6SPD
Date: August 22, 2016 09:24AM
Conner,
The pot and wiring diagram is included with the Bruno Box.
Here's the link on EBay:
[www.ebay.ca]
Ken
TR6-6SPD
Ken Hiebert
Toronto Ontario
(255 posts)
04/23/2008 11:43AM
Posted by: TR6-6SPD
Date: May 26, 2017 06:51AM
I finally got around to installing a "preset" circuit and switch for the amount of steering assist I want. I found I was checking the position of the potentiometer unnecessarily as I never really moved it off the 2/3 rds. spot. Having the rocker switch at preset gives me that, or "off preset" lets me adjust further.
Edited 1 time(s). Last edit at 05/28/2017 06:45AM by TR6-6SPD.
Dan B
Dan Blackwood
South Charleston, WV
(1007 posts)
11/06/2007 01:55PM
Posted by: Dan B
Date: May 26, 2017 10:58AM
Ford light switches....
