geezer Charles Durning Magee, MS (60 posts) Registered: 11/16/2017 01:16PM Main British Car: 1974 MGB, 1967 Morris Minor |
Little to no hydraulic pressure to the rear brakes
Ever since I resurrected my 74 GT I felt the brakes were not up to standard. I did overhaul the entire system including wheel cylinders, calipers, flex hoses, front pads, and rear shoes and hardware. The master appeared to be new before parked and bled quickly to a firm pedal. I did notice when bleeding the rears that the fluid did not expel with the same gusto as the fronts. I didn't think much of it at the time.
Now that I have converted the rears to disc I thought there should be a marked improvement in braking. They didn't seem to be perform as I had expected. On a whim I had the wife push on the brake pedal with the wheels in the air and I can still turn the rear wheels by hand. Drat!!! The fronts work as expected. None of the hard lines to the back brakes are smashed. I did not remove the trap valve from the rear circuit of the master cylinder. Is there a known issue with the master not producing pressure for the rear circuit? |
Re: Little to no hydraulic pressure to the rear brakes
Charles.
There is a definite possibility that the master is at fault. Especially if it has sat for a long period of time. The cup seals on the plungers swell and cover the ports that admit fluid from the reservoir. A more likely scenario is that the brake failure warning valve has tripped. That is # 28 on your diagram. When this valve trips it closes the port to the offending end of the vehicle. It should turn on the brake warning light, but it does contain Lucas parts so......... Try re centering the valve by opening a front bleeder and giving the brake pedal a sharp stab. Live like you mean it. Fred |
Thanks, I'll look at that before condemning the M/C. For some reason I didn't think the shuttle would close off a hydraulic circuit. In a past life after doing a brake overhaul I would pull the contact and center the shuttle manually tp shut off the light. Just didn't occur to me this time. The light must not be working.
If all else fails I do have a new M/C. It's just a PITA to change. |
spridget bill green Maine (68 posts) Registered: 03/22/2008 01:29PM Main British Car: 3 1980 TR8, 1 TR7 2 Bugeye Sprite 1 MG midget TR8 3.5 and 5.0, Sprite 1098 and ? |
Consider using stainless steel flex hoses. The rubber ones can swell and restrict flow. I had that happen on a new hose.
Did another bleed with a pro helping instead of the wife. All is well now.
