Source for brake M/C
The Mark-I MGB used a metal canister type 3/4" bore M/C, the early Spitfire used the same M/C with an 11/16" bore.
I need one with a 5/8" bore. Does anyone know what car that was used in? Jim |
Re: Source for brake M/C
Might try Wilwood
[www.ebay.com] [www.ebay.com] Lots of motorcycles use 5/8"bore cylinders but might not be configured right for your application. Austin Mini had a .70" bore master. Edited 1 time(s). Last edit at 06/10/2018 10:50AM by ex-tyke. |
Thanks Graham, that'll be the last resort as I'd have to reconfigure the line(s) and I'd rather have matching M/C's. My balance bar needs a little help as it is at the end and still needs more.
I'd like to stick with the tin-can reservoir OEM type if I can find one. The Mini is a little closer than the Spitfire/Midget one but my calculations indicate the 5/8" would be a better match. Jim |
Might investigate re-sleeving your 3/4" M/C and getting a 5/8 rebuild kit and piston.(you're good at lathe work)
Do it yourself or have White Post do for you. [whitepost.com] Edited 1 time(s). Last edit at 06/10/2018 12:58PM by ex-tyke. |
Actually that was wrong, the 11/16 bore is less than .700" so the Spitfire M/C would be better than the Mini.
But my guess is that an earlier car, maybe something pre-disc brake would have used a 5/8" bore. Jim |
geezer Charles Durning Magee, MS (60 posts) Registered: 11/16/2017 01:16PM Main British Car: 1974 MGB, 1967 Morris Minor |
Jim,
You might look into a clutch master cyl from a Midget, Sprite, or a Spitfire. If memory serves me they are smaller than the brake cyl. |
Yes, they are 11/16". I need 5/8"
I assume that you want a dual circuit M/C (rather than a single)
Might not be anything out there that small ......I still maintain that sleeving is a viable option. |
Actually Graham I'm looking for a single circuit M/C and would also consider a clutch M/C. I have a twin master/balance bar setup, with dashboard adjustment knob. Currently both M/C's are 3/4" bore just like the mark I and II cars use.
Apparently the Minx used a 5/8" M/C for the clutch which I think would work, Lockheed No. 4223-917 Where to get a new one is the question. Jim |
If your looking for a basic single circuit master, check the Dorman website for clutch masters . Here's one 5/8" bore example for a Ford Courier.
[www.dormanproducts.com] Edited 1 time(s). Last edit at 06/11/2018 08:41PM by ex-tyke. |
That Dorman does look pretty good. I've sent Kelvin a note to see if maybe Moss might have the Minx part. If not I may have to go with one of those types.
Subaru uses a 5/8 clutch master
[www.rockauto.com] From a Mazda [www.rockauto.com] Edited 1 time(s). Last edit at 06/12/2018 10:45AM by geezer. |
Thanks Graham, I just sent them an email.
Moss has the .700" one for the midget. Jim |
Got one coming from UK. NOS, hopefully get here in the next couple weeks.
I'll post a photo when it gets here but as far as I can tell it looks just like the early MGB round tin can master. (or clutch M/C which is what it is) May be zinc galvanized rather than cadmium chromated.
Application is Rapier Minx, part number is Lockheed AP # 4223 - 917. No longer being made according to one source. N.O.S. like I mentioned, no idea how many are left. My guess, not many. Jim |
