tr8todd
Todd Kishbach
(390 posts)
12/04/2009 07:42AM
TR8 5 lug aluminum hubs
Posted by: tr8todd
Date: February 22, 2019 03:06PM
I'm tossing around the idea of having a machinist make me up some hubs out of 6" round stock 6061 aluminum. Not entirely happy with the trailer hubs I mocked up. Too many spacers to inspire complete confidence that everything is going to hold together at very high speeds. Thinking about making hubs that are fairly close to TR8 hubs except the brake rotors will fit on the front of the hub instead of bolting to the back. 5X4.5 wheel bolt pattern to match the common Ford pattern. This will allow narrowing a Ford 8.8 without ordering custom axles, and will open up a wider selection of aftermarket wheels. I can either have him make me a couple of sets in the lathe, or I can try and find somebody with a CNC machine. The CNC set up is only worth it if somebody other than me wants these things. Once its programmed, he can run off as many as I want. Material costs should only be about $50 a piece, plus bearings and studs. Is there anybody, other than me, that has any interest in this? For me, its an easy button to solve all of my wants in the best way. Light weight aluminum hubs, with the correct offset, set up for Wilwood aluminum hats and vented rotors.
WernerVC
Werner Van Clapdurp
Lynchburg, Va
(108 posts)
09/06/2009 12:56PM
MGB 1977 Rover 3.5
Re: TR8 5 lug aluminum hubs
Posted by: WernerVC
Date: February 27, 2019 10:28PM
Hi Todd,
Can you give some more details about the 5 lugs hubs ?
I have a set of vintage Maxilite wheels that I want to install on the rear end of my MGB. So I am very interested if you can get the 5-lug hubs. The bolt pattern must be 120 mm. These rims are brand new, never used and would fit for a Jaguar. Same bolt circle as Chevrolet.
Let me know about that project asap. More details on rotors and set up please.
Werner
Aluminum Front Hubs
Date: February 28, 2019 11:35AM
I like the series II RX7 hubs, light, strong design with adequate bearing/spindle sizes. Art.
Re: Aluminum Front Hubs
Date: February 28, 2019 12:12PM
How about some details on those Art?
Date: March 05, 2019 05:42PM
Deep cross section like Porsche, only Japanese cheap,(many produced). I used larger shoulder, 1/2-20 studs to arrive at 5 on 4.5" bc. Art.
Date: March 06, 2019 01:07PM
Good. Is it a direct fit on the MGB spindle? Does it use the same offset? Can it be used for chevy pattern as well? (5 on 4.75")
WernerVC
Werner Van Clapdurp
Lynchburg, Va
(108 posts)
09/06/2009 12:56PM
MGB 1977 Rover 3.5
Posted by: WernerVC
Date: March 08, 2019 08:39PM
Jim,
I am fighting the same battle. Hope to find 5-lug spindles that fit the MGB spindles. Too bad the MGC spindles are a very rare beast.
That would be a perfect fit.
Hope to get an answer soon from Art.
Werner.
PS.: I have a set of new Maxilite rims with bc of 120 mm used for a jaguar. Cannot find nuts for it. Anyone has a source for it. I need 15 of them . Nuts have 1/2" threads and shank is 3/4 "
(2463 posts)
Date: March 11, 2019 06:11AM
The RX7 hubs use straight cartridge bearings. I remember that Art bored them out for Mustang II or GM bearing races. Mid 80's Series II N/A had 4 lug same as MGB and Turbo had 5 lug Ford pattern.
Edited 1 time(s). Last edit at 03/11/2019 06:12AM by mgb260.
flylear45
Jim Franks
(8 posts)
11/28/2013 07:29AM
Posted by: flylear45
Date: March 24, 2019 08:38AM
Todd,
I am definitely interested in a set of hubs.
On my turbo TR7 I am presently running a stock width 86 Mustang 8.8 rear with Moser axles, and using Contour FWD offset (~45mm IIR) wheels all around. Mustang bolt circle, but the center bore is slightly smaller. I had to have my rear axles concentric hub centers turned to fit the Contour wheels.
The FWD offset poses a dilemma on the front because the front ends up way too narrow, so I had custom spacers made to push out the front wheels. I have a large outer bearing in the hub along with a tube spacer to enlarge the outer axle diameter for the bigger bearing.
It's OK but not ideal. I am currently using Merkur front brake calipers along with a custom bracket. I have to drill rotors to renew the brakes.
I am definitely interested in an upgrade since it's about time for rotors!
Jim Franks
tr8todd
Todd Kishbach
(390 posts)
12/04/2009 07:42AM
Posted by: tr8todd
Date: March 24, 2019 08:40PM
One of the local TR8 owners has a son with a CNC machine in his garage. I just need to draw up the hubs for him to plot in, and then get some 6" round 6061 for him. Once they are plotted, he says he can run one off every 45 minutes or so for me. He owes me a favor as well, so I just need to get off my butt and draw up some plans for him. Spent today making up adjustable rear lower control arms for the 8.8 axle I have. They have urethane bushed ends, grease fittings, adjustable length on one end, and spring perches set at 14* to mimic stock spring angle. Set up for 2.5" ID springs with threaded sleeves on top against the frame rails. Still undecided about how I want to do the sway bar mounts. The stock bar will hit the aluminum Ford dif cover if I mount it in the same basic spot as the stock lower control arms. Thinking I will make a shark fin steel plate under the tube and mount the sway bar to that. Just make the mounting holes a little lower, and a little farther back to gain the clearance I need.
Date: March 25, 2019 11:50AM
Yeah, and that's where we generally run into trouble since the volume just isn't there. Probably $50 just for the blank for one hub, then machine time, tooling costs and setup time, then bearings seals and studs, by the time you add in enough to make it worth your time the market has diminished to the point where the volume doesn't justify the effort in many cases. The TR8 is very much a niche market, and not a particularly large one. So you cut your profit in an effort to boost volume and in the end it's just a hobby that you are doing for your friends.
Don't get me wrong, I love to see things like this being done. The TR6 brake brackets were a great thing. Just don't quit your day job.
(4513 posts)
Date: March 30, 2019 11:19AM
Lots o' meat left on those rotors, Jim F. :)
flylear45
Jim Franks
(8 posts)
11/28/2013 07:29AM
Date: March 30, 2019 04:01PM
Unfortunately that picture is 10 years old! I have a fair number of miles on the conversion now, and am in the process of planning for a complete re-fresh with some new mods.
