Re: NO BRAKES !!!
Hello and welcome.
Wow, subtle work there. Shades of the Flying Tigers. If you're going to drive it in that livery, you're a braver man than I. So, no brakes when you bought it? It bled out OK and it's not leaking.... and if there were an air lock you'd still have some pedal. Frustrating. There needs to be a slight clearance between the master and the pushrod so the cylinder can return fully and uncover the recharge port. Perhaps 15 thou. Otherwise you're pushing air. There may be an adjustment on the pushrod, locknut. Or not. If there is an integral servo, the adjustment will be on the front end of the servo. If it worked before, carefully measure the backend of the old cylinder against the new one. Rear drums... if they are really really worn and backed off, could be that all the travel is being taken up moving the drums into contact with the drums. Assuming they are manually adjustable, adjust them until they just about don't rub. But I'd reckon on the pushrod. Ivor Edited 1 time(s). Last edit at 05/09/2019 01:56PM by 88v8. |
Re: NO BRAKES !!!
Sounds like a bad master cylinder to me.
Re: NO BRAKES !!!
The Flying Tigers didn't use Spitfires, though.
Even with the rear drum brakes not adjusted properly, there should be some brakes. I would be looking in the direction that Jim mentioned. |
