Quarter- Eliptic, Composite, Mono Leaf Springs
Front straight axle with about 400lbs, static corner weight. Urethane bushing at axle end, {compliance}. Spring is inverted for better rising-rate and ro[l-caster gain, as an upper, leading link. Question is, mounting diagonally, to handle lateral loads ? Not likely to exceed 1G lateral. Using metal lower leading link. Anti-roll bar may attach to ether link. Second design is "pickle fork", with roller bearing mounted on real side of axle,( slides up/down in slot). Thoughts ? Thanks, Art.
Re: Quarter- Eliptic, Composite, Mono Leaf Springs
KISS?
I think I need a sketch... and some context: What car would you put this under?
First to JB., KISS, not helpful. Why bother ?
To Curtis, thanks for answering. No skill to upload sketch, but this is the Rover V16, all aluminum roadster, cept' f-glass body. Entire drive train is stress-mounted which makes 1/8" wall aluminum frame, workable. Since aluminum engine girdle direct receives . input load from quarted-eliptic monoleaf, loads are acceptable. About 1.5" squash and 2,5"dangle, travel , at wheel, should be enough( straight axle). Thanks, Art. |
Roverbeam Chad McNeely N.E. MO (76 posts) Registered: 06/09/2021 06:03PM Main British Car: Alpine S4 Rover 4.0 |
Front straight axle and leaf springs sounds like pre-war stuff, or a truck. The guys that make “cyclekarts” (HF predator motor, Honda 90 bike tires, homemade chassis…) are big into the pre-war examples for their half-size “replicas”. The site is at least a decent repository of example cars/chassis/suspensions that aren’t difficult to copy.
I did a composite transverse 1/4 leaf design with lower A-arm for an Auto Union Type C I spent a week deciding whether to build… |
"Question is, mounting diagonally, to handle lateral loads ?"
Do you still plan to use a panhard rod, Art? Straight axle street rod stuff is before my time. Maybe something in here may help: [www.jalopyjournal.com]\ I enjoyed this little history lesson on straight axle street rods. [www.motortrend.com] |
