Rear Suspension - Coil Spring not Coilover
A post over on that other forum has sent me down the rabbit hole today.
Using coil springs in the rear of an MGB is something I have pondered over the years. I vaguely recall the MGB designers tried coil springs, but they did not like the handling. What did they use to retain the rearend laterally? Maybe that was the reason. Anyway, I believe it to be do-able. Edited 1 time(s). Last edit at 08/29/2023 04:26PM by MGBV8. |
Re: Rear Suspension - Coil Spring not Coilover
Fox Mustang is similar but 2 upper links for triangulated 4 bar. A lot of Cobra kit cars use it. some have done away with the coil springs and went with coilovers where the shocks are. Only with stronger mounts. Probably for the cool look.
Edited 1 time(s). Last edit at 08/29/2023 05:42PM by mgb260. |
The rate of the springs will need to be calculated based on the position on the LCA. MGB front springs are rated for about 200% of the corner load due to the 50% lever arm reduction. So travel is also about 50% of spindle travel. Exact numbers would require exact measurements.
So, there is no reason why you couldn't use full size coil over springs. I think it might be better than using the 2" ones we've been seeing and there should be plenty of room for them. Ideally the spring seat would be in line with the two pivots, at the body and at the axle for even loading. That would determine the top spring seat location. I think that puts it in line with the frame rail though and I'm not sure there is enough vertical space there. The spring could also be angled forwards but that raises the spring rate. Jim |
In the past, I have read about the Mustang triangulated uppers causing bind. May not be an issue when not very much travel.
Yeah, no room for the spring on top of the axle. Plenty for full size coil spring forward of it. I have seen that on production cars and NASCAR.
Might use a lower link similar to some of the traction links being used, if needed a drop section for the spring seat, then either triangulated upper links like in the CCE 4 link kit or a single top link and a whatchacallit for sideways. Shock might have to be behind the axle.
I really like the adjuster idea. Looking forward to seeing someone take off and run with the concept. It's too good not to get done.
Coil-overs, proportunately are pretty high. Personally, I don't like the lateral arch of a panhard bar, especially with tight tire clearance.. A watts link has better properties but is more complicated. "What if", the outer ends drove a torsion bar ? No coils needed. Might fit better in tight constraints.
Art. |
Mmm, doesn't the bar itself define the rate, the hex just raises or lowers the susp?
Carl
"MG was aware of the ride issue long before the first MGB was even built. According to an interview of MGB designer Don Hayter (which I found in Ken Smith's excellent little book "Aspects of Abingdon" as published by MG World, copyright 2006), the very first MGB prototype was fitted with a trailing arm and coil spring rear suspension that included a Panhard rod for side-to-side axle location. A similar suspension had been installed on MGA developmental vehicles. The factory engineers preferred coil spring suspension over leaf springs to achieve a smoother ride. Ultimately though, MG engineers were unable to overcome a slight steering effect caused by fitting a too-short Panhard rod". This is copied from [www.britishv8.org] |
Seems they could have used a Watts linkage...
I read an article about that long ago, Philip. That is a good part of what had me pondering this approach. It is also why my panhard rod is 35-36 inches long. :)
The Watts was part of the plan, Jim. They went with the cheaper panhard rod that doomed the 4 link.
"Enever and chassis engineer Terry Mitchell explored a variety of alternative suspension layouts in hopes of smoothing out the ADO23’s ride without sacrificing handling. The ideal solution would have been to reduce the rear unsprung weight with either independent rear suspension or a De Dion axle like that of the EX181, but cost considerations precluded either. As a compromise, Roy Brocklehurst, who had designed the original MGA chassis, came up with a four-link design that traded semi-elliptical leaf springs for coils, locating the axle with four trailing arms and a Watt’s linkage, later exchanged for a cheaper Panhard rod. The new suspension provided a much better ride, but the Panhard rod mounting caused structural problems and erratic handling. Given time, those problems could undoubtedly have been resolved, but with the project already running well behind schedule, Brocklehurst and Mitchell decided to retain Hotchkiss drive. The production car’s sole concessions to improved ride quality were redesigned spring shackles and longer (and thus softer) leaf springs, the addition of which required the tail to be stretched about an inch (25 mm)." [ateupwithmotor.com] |
