Goto Thread: PreviousNext
Goto: Forum ListMessage ListNew TopicLog In
pawp
Richard Carr
Louisa VA
(10 posts)
11/26/2008 12:17PM
1980 MG B Buick 215
Brake line routing
Posted by: pawp
Date: July 11, 2010 08:13PM
Got a question ya'll. Any thoughts on routing the front brake lines through the inner fender well ( with appropriate grommets)for a more direct path to the wheels? This is for a '80 dual brake system. The plan is to keep the lines away from the block hugger headers on the BOP 215.
Cypress, TX
(721 posts)
Re: Brake line routing
Date: July 11, 2010 09:42PM
Make sure a blow out wouldn't catch them & tear them out. Wouldn't want to lose a tire & brakes @ the same time.
(1811 posts)
1971 MGB Blown, Injected and Intercooled Olds 215
Date: July 12, 2010 09:57AM
Can't really use the brakes to stop after a blowout anyway. ;-)
JB
Canada
(48 posts)
Do you mean one that runs? Engine by lotus, about 2 foot square.
Date: July 12, 2010 02:08PM
No problems that I can see.
Make sure everything clears @ full lock and suspension compression.
Use a solid mount at the termination to the flex line to keep the hard line from stress fracturing.
Use the best grommets that you can find. Use nylon or insulated clamps to mount the line ( no rub through )
Make the lines one piece. Legaly they can't have any couplings in them.
Lastly don't mount the lines in any of the crevices where they can collect debrise and rub through or rust.
If it were mine I'd hammer out some covers for them. Looks pretty, protects the lines and gives you something to bragg about.
Cypress, TX
(721 posts)
Date: July 13, 2010 04:37PM
RE: Can't really use the brakes to stop after a blowout anyway. ;-)
That's true on the side that blew out, but not the side that didn't. Often there's a T btwn the two.
