MG four six eight Bill Jacobson Wa state (173 posts) Registered: 10/23/2007 02:15AM Main British Car: 73 MGB Buick 215, Eaton/GM supercharger |
Re: Steering Damper
Chris
The steering dampener does help. The biggest difference I noticed is when driving over railroad crossings. Jim is correct though in that the farther out-board your wheels are spaced, the more sensitive the steering will be to road shock. Bill |
cgill Chris Gill Salmon Arm, British Columbia (91 posts) Registered: 08/13/2009 12:06AM Main British Car: 1979 MGB roadster Buick 215 with rover 3.9 heads and EFI |
Re: Steering Damper
I'm only running a 1/4" spacer on each front wheel. Would removing that make much of a difference?
BlownMGB-V8 Jim Blackwood 9406 Gunpowder Rd., Florence, KY 41042 (3482 posts) Registered: 10/23/2007 12:59PM Main British Car: 1971 MGB Blown,Injected,Intercooled Buick 340/AA80E/JagIRS |
Re: Steering Damper
It could make just enough.
JB |
MGB-FV8 Jacques Mathieu Alexandria, VA (263 posts) Registered: 09/11/2009 08:55PM Main British Car: 1977 MGB Small Block Ford, 331 Stroker |
Re: Steering Damper
Wheel offset can complicate the original OEM center line design; caster change can also contribute to wheel shimmy. Here a nice article on steering and alignment problems.....
[www.niumotorsports.com] Jacques |
74ls1tr6 Calvin Grannis Elk Grove,CA (765 posts) Registered: 11/10/2007 10:05AM Main British Car: 74 TR6/ 73 Spitfire / 71 MGB GT TR6/Ls1 Spitfire/stock 71 MGB GT/stock |
Re: Steering Damper
I would agree, that the further out the wheel is mounted from center line of hub and wider tires would result in road shock. I'm running a bolt on 1" spacer from 4 x 4 1/2" bolt pattern to a 4x100mm bolt pattern, with a 45+ mm offset wheel. Let me tell you that when I hit any bump or slight pot hole on the freeway, I need to be holding on to steering wheel. The tire width or foot print is about 9 1/2 " on the road with a 245/45/17 tire.
I will be looking into this shock setup very soon. I thought is was bump steer but my car didn't move off the straight line of travel. Edited 1 time(s). Last edit at 11/18/2011 06:10PM by 74ls1tr6. |
roverman Art Gertz Winchester, CA. (2288 posts) Registered: 04/24/2009 11:02AM Main British Car: 74' Jensen Healy, 79 Huff. GT 1, 74 MGB Lotus 907,2L |
Re: Steering Damper vs scrub radius
I consider scrub radius the enemy. I suspect some folks run a larger steering wheel or dampeners, because of excessive amounts. Calvin, it sounds like your car suffers from positive scrub radius ? Can you adjust for more ball joint/king pin inclination, to reduce the scrub radius ? Good Luck, roverman.
Re: Steering Damper
Art,
Took the TR6 to Les Swab here in town and had a 4 wheel alignment done. It needed it for sure since building the car. I had it pretty close from eye balling it. Front needs more caster still, but I added metal plates(to stengthen) at the wishbone arms attaching points. By doing this I need to install lomger bolt studs for more caster adjustment. Front and back I'm running negative camber @ 1.5 all four wheels. Front toe in 1/16... back 0 toe in Running 30psi in all four tires and myself in car while doing the alignment. So after alignment it was a world of difference. I'm in the process of adding 12.19 vented rotors up front with Wilwood 4 pot calipers. At that time when apart, will add in loger bolts to achive more caster. Also my suspension doesn't have much deflection because of the use of nylatron bushings. That being said, I feel everything at the steering wheel. When apart, I'm taking out a 3/4" spacer under the spring to lower the front back down an 1". In the end I think it will curb the problem out. Thanks Art for your interest! |
Re: Steering Damper
Calvin, some irs's use small toe-out at static, knowing they will pull in under load. Cheers, roverman.
