MGBV8 Carl Floyd Kingsport, TN (4014 posts) Registered: 10/23/2007 11:32PM Main British Car: 1979 MGB, Buick 215 |
Re: Electric Power Steering
Quote: In most cases, of course not, James. It can make all the difference for some. |
Carl, I agree and think that having the assist at lower speeds and the automatic speed sensitive control to reduce or cancel the assist at higher speeds is the ideal solution. This is what the current technology in the newest cars does. The requirement with the Saturn based systems to adjust (via the Bruno controller) does this but it is not automatic. The Yaris based system does this automatically but requires a pulse generator to "wake" the system up upon starting. The new DCE system seems to do this. All comments are welcome. Anyone out there have experience with the DCE Microsteer system?
BlownMGB-V8 Jim Blackwood 9406 Gunpowder Rd., Florence, KY 41042 (5985 posts) Registered: 10/23/2007 12:59PM Main British Car: 1971 MGB Blown,Injected,Intercooled Buick 340/AA80E/JagIRS |
Be aware, the EPS will change the steering characteristics of the car whether it is on or off. What you have is a fairly large ring gear being driven by a worm gear on the assist motor. The worm and ring creates resistance. When unpowered that adds to the heavieness of the stock steering, and it reduces the snappy return-to-center that the OEM arrangement creates whether powered or not. Any reduction in camber or caster (particularly caster) will also reduce that effect, whereas wider tires will add to it.
So, adding EPS will reduce steering effort but also reduce return-to-center (which is a bit excessive in the stock MGB anyway). But without power it makes the steering a good bit heavier, as well as the reduction in return-to-center. Jim |
I found this interesting:
The Miata has Mazda’s second implementation of rack-mounted electric power steering The first application was in the RX-8, but while most modern Mazdas use electric power steering, it’s really tricky to fit rack-mounted systems in front-wheel-drive cars. In the 2016 Mazda MX-5 Miata, a rack-mount assist system allowed engineers to improve steering feedback (other cars have the assist system in the column, which is less precise). Mazda did experiment with unassisted steering for the new Miata, but officials say the effort at parking speeds would have been too high. |
Carl, Interesting comment. I have two modern cars--the older is a 2018 Chrysler 300 AWD with electric power steering on the rack as the Miata. The steering feel is good with a dampened return to center and almost no caster feel in the straight ahead position. This gives the car a light feel on the highway but the car does not wander. I suspect this feel is programed in. The second car is a slightly newer 2018 Ford Fusion Hybrid. This car has the has the electric power steering on the column and is virtually the same feel as the Chrysler. Again I suspect that is the programming. Both systems are speed sensitive.
This brings me to my present decision. I have decided to through some bucks at this and have purchased a DCE Microsteer system from Flaming River. The unit is in my hands and I plan this week to build some column and bracketry parts. I also hope to do some bench testing. This system goes both ways with a control much like the Bruno controller and an option for a pulse width speed input. I will be using the input from my GPS speedometer at 8000 pulses per mile. Unfortunately road testing will not be done until sometime this fall, when the progress of my V8 conversion is back on all fours. I will post information as available. As always comments are welcome. BTW, I know that I had said that I did not think the EPAS was all that necessary, but it sure would be nice to have the low speed assist with the highway feel of the unassited MGB. Of course the highway experience will never be as "strong" as a non assisted MGB but if it is as good as either of my two modern cars, I will be quite pleased. Comments and observations are always welcome. |
b6281t Robert Stolt Glenwood City, WI (16 posts) Registered: 03/01/2015 10:39AM Main British Car: 77 MGB 2008 GM 3800 with T5 |
I just repeated reading of the recent posts. I was looking to see what the Roadmaster has in it for Power Steering. Did Jim Blackwell install a EPAS in the Roadmaster or was that in his own car? Will the Roadmaster be at the V8 GT in Townsend this year? Thanks to all.
Since James joined us at the GT in Townsend, his question were answered. For those that were not, yes, the MG Roadmaster now has EPS (EPS column built by Mike Moor & installed by Jim Blackwood). And, no the MG Roadmaster was not there.
Jim has also installed EPS in his own MGB. Edited 1 time(s). Last edit at 04/06/2020 11:29AM by MGBV8. |
The collapsible column feature should be retained if possible, MGs have had a collapsible column since the Mark-II I believe.
I agree with you Jim. It should be kept, even if greatly reduced. The drive assembly did take up a lot of the space available for the collapse feature. Like I stated, I could have kept maybe 2 inches of collapse(ability?) had I had enough forward vision to do my cuts accordingly. I made a judgement call that I am OK with. I do not recommend others follow.
