psmg Paul Schils Fredonia, WI (90 posts) Registered: 12/13/2007 10:27AM Main British Car: 1973 MGB-GT, Buick 215 1971 MGB RD, SBF 302 |
Re: Electric Power Steering
The big improvement with electric power steering ,along with what everyone has mentioned , is the total lack of vibration and harsh steering wheel movement while traveling. I'm much less tired after long trips, similar to current automobiles. This is welcome the older you get.
I have fabricated and installed EPS on my MGB , my MGA and my Fiero and am very pleased with each installation. Thanks to Mike Moor for starting this improvement. |
302GT Larry Shimp (245 posts) Registered: 11/17/2007 01:13PM Main British Car: 1968 MGB GT Ford 302 crate engine |
I just removed the caster wedges from the front crossmember and so the caster is back to 6 degrees. The improvement is noticeable in that the steering feels more precise now, with some more feedback. The Moss quick ratio rack I have seems ideal for use with this set up.
Of course it should be kept in mind that Larry is running the Hoyle front suspension. Whether his results will cross to a stock king pin suspension or not is an open question.
Also, shameless plug here for Mike Moor's EPS conversion, as it remains the easiest way to do this and works very well. Jim |
Hoyle still uses kingpins. Not that that matters. Negative camber gain is the direct result of the amount of positive caster when the suspension is compressed.
Carl is correct; one of my motives to install the power steering was to be able to take advantage of the camber gain with the stock caster angle. The rear suspension grips so well there was always some understeer with the caster wedges, this is now gone as I hoped it would be. I did experiment with negative camber on the front suspension but that has too many compromises.
I also agree that Mike Moors' steering is a fine alternative. A short drive in his car two years ago convinced me that I could be happy with power steering, but I also wanted to try the speed sensitive feature. |
Scott68B Scott Costanzo Columbus, Ohio (569 posts) Registered: 10/25/2007 11:30AM Main British Car: 1968 MGB GM 5.3 LS4 V8 |
I'm a little late to the party but I started to disassemble my dash in prep for adding EPS this afternoon. I was intrigued with the Yaris unit and that's what I got this week. It's a non-ABS unit. The main reason I went this route is because you can add a VSS signal and the unit is supposed to run like factory......less boost at higher speeds. There is a good writeup on this site:
[mgaguru.com] Based on the above article, I can confirm that the unit requires VSS pulses to become active. The easiest way for me to test it was temporarily wiring it into my car to get access to a VSS signal. The article says it requires 5 pulses to become active, which is roughly 6' with a GM system. So backing out of a parking space should get you there. I'm anxious to get it installed to see how it performs in the B. One of the things I wasn't aware of was the damping these units apply to the steering when going down the road. The article talks about this in detail. I had considered installing a VW steering damper at one point so I'm looking forward to experiencing this as well. I hope to be closer by this time next week and I'll update everyone here when I have more to report. On a related note, my wife has a 2015 Corolla with EPS. It has good self-centering, FYI. I believe it only has about 3 degrees of caster. |
Quote: So, if you are parallel parked, you are SOL? That is when one would need it the most. ;) |
Good question Carl. Are you there Larry?
On a related note, my alignment check showed caster of just barely under 7 degrees after installing the reverse caster wedges. They are about 3/8" tapering to maybe a 32nd or less. With the Prius EPS self centering is pretty much non existent. Jim |
Dan B Dan Blackwood South Charleston, WV (1009 posts) Registered: 11/06/2007 01:55PM Main British Car: 1966 TR4A, 1980 TR7 Multiport EFI MegaSquirt on the TR4A. Lexus V8 pl |
Dan, is it from an ABS or non-ABS car? Is it a winter project or are you trying to install it before Townsend?
2012. I don't think it was ABS. What difference does that make?
I have a 81 TR7 parts car out by the barn with briars and crap growing all around it. I should be able to get the column out of it and then we can see how much difference there is between the MG and TR7. Hopefully I have a little more room to work with.
Dan, not sure if your unit is the same as the one I have but it sure looks like it is. They say 2006-2011 for the Yaris but that might be what was known at the time the post I looked at was created. If it is the same as mine, non-ABS, you'll need to either give it a VSS signal or put power to pin D31-5 to get it to work. If not, then you'll be running in limp mode. Read the link I posted a couple of posts ago. It has a bunch of information about the Yaris EPS including the wiring.
Quote: Tsk, tsk. you haven't been doing your reading assignment, Dan. ;) You may be okay. We will see. Go back & read (or re-read) Larry Shimp's posts. |
Scott wrote: "If it is the same as mine, non-ABS, you'll need to either give it a VSS signal or put power to pin D31-5 to get it to work."
I do have a sensor (magnets attached to the driveshaft) that I installed long ago with the cruise control. Not using with the cruise, since I am using tach signal for that. I wonder if it would work with the EPS box. |
Hard to say. VSS sensors typically have a considerably higher pulse rate.
Quote: Dan, that's convenient and it should work. In the article I linked to, the guy used a 4 tooth reluctor located on his differential flange to run his unit. I'm hoping to have mine ready by the end of this week. |
