suspension ride height sensor
If memory serves me, there was an oem, lever operated sensor, on rear for pick-ups. I think this sent an ohm signal for brake bias or load leveling. It doesn't matter, I just need this device. Jim B., do you copy ? Thanks, roverman.
Re: suspension ride height sensor
what for roverman? Would a fuel gauge sender work? Lots of choices & ohm ranges.
DiDueColpi Fred Key West coast - Canada (1373 posts) Registered: 05/14/2010 03:06AM Main British Car: I really thought that I'd be an action figure by now! |
Hey Art,
there are tons of sensors out there that would serve your purposes. The first one that comes to mind is Land Rover. Every air suspended one had 4 of them. Cadillac has used them for years and so has Ford. Jaguar / Mercedes and many others as well. The aftermarket is full as well. Check into any Air bag company and you will find a selection. Hope that helps Cheers Fred |
Re: suspension ride height sensor, absenteism
I must seem unaware of all available in dynamic controlled air suspension. well, I am, but at least I know enough to ask those who actually know something/lol. Thanks, roverman.
