mgb260 Jim Nichols Sequim,WA (2632 posts) Registered: 02/29/2008 08:29PM Main British Car: 1973 MGB roadster 260 Ford V8 |
Re: Where to go for hub specs?
Nope, Different bearings. You may be able to bore/sleeve (copy Healy specs)in Mazda RX7Turbo II hubs.
Re: Where to go for hub specs? RX 7 series II
Fred, Which Healey ? Jensen is tiny. Clan, Overall width is 3.0" and od is 5.75". Looks "iffy" on redrilling pattern between existing (5) on 4.5" bc. studs. "Might" go with larger dia. shoulder studs to offset bore existing holes/changing bc. Your results may vary. Good Luck, roverman.
Edited 1 time(s). Last edit at 03/12/2012 12:56PM by roverman. |
Anybody thinking about swapping out hubs might want to look over this Wilwood page. It lists all the aluminum replacement hubs they sell, what they fit, what bearings they use and most importantly bearing spacing. [www.wilwood.com] As long as you find one that uses the same bearings or smaller, you can machine the aluminum hub to the right specs. Pretty sure they all start from the same blank. I'm playing with the idea of using the Mustang 65-66 Mustang V6 or Mopar a-body 9"drum spindle application hubs on a TR8.
These are my three options. [www.wilwood.com] The TR8 uses A4 and A1 bearings. The common upgrade is to drill out the stock hub to accept an A2 bearing and then put a sleeve over the spindle to make up the difference in the inner race. The bearing spacing(measurement M) on the wedge needs to be around 2.3", so the bearing pocket will need to be machined a little deeper for the bearing to ride on the spindle properly and not hang over. I'm leaning towards the A body hub designed for vented rotors and a set of 12.19"X.81" vented rotors. You can get those hubs with a 5X4.5 wheel bolt pattern that will match the Ford 8.8 rear end. One of my TR8s has Rover SD1 struts and hubs. Those hubs use A6 and A2 bearings, so finding a hub for that car will be much easier. There are a ton of American cars that used those bearings.
