RoverP6B
Graham Ware
(10 posts)
08/28/2008 09:59PM
Vacuum for a brake booster, manifold issue...
Posted by: RoverP6B
Date: October 28, 2013 03:49AM
I have a Rover V-8 and a decent downdraft 48IDF Weber setup to replace the twin SUs.... it has occurred to me that, as the Weber manifold is of the individual-runner type, its going to be difficult to tap vacuum off the new inlet manifold to power the brakes which is how its currently done
OK, the picture is for a Ford but you get the idea...
Any ideas for a solution ? I am guessing I could make spacer plates under the carbs which tap intake pressure, and join these up somehow... but I am guessing there might be a more elegant solution...?
best
Graham Ware
Edited 1 time(s). Last edit at 10/28/2013 03:51AM by RoverP6B.
(4637 posts)
Re: Vacuum for a brake booster, manifold issue...
Date: October 28, 2013 11:35AM
How would you feel about using an electric vacuum pump? (Example)
Re: Vacuum for a brake booster, manifold issue...need more foot
Date: October 28, 2013 12:04PM
So many, much heavier cars were built, without power assisted brakes,(including disc in front). Is it that much effort ? Ever tried to stop a power assisted brake system, with a dead engine ? Good Luck, roverman.
(1389 posts)
Date: October 28, 2013 12:15PM
Hey Graham,
Your answer is in the ford picture.
The little polished pipe at the base of the #1 intake runner is likely a brake vacuum take off.
Each runner will have one that runs to the back of the manifold and joins up into a small plenum.
The plenum is then tapped for the booster or whatever vacuum driven device that you have.
This is also the way that you would supply a manifold pressure signal to a speed/density type fuel injection system.
RoverP6B
Graham Ware
(10 posts)
08/28/2008 09:59PM
Posted by: RoverP6B
Date: October 29, 2013 05:33AM
Curtis: thanks that looks like just what I was looking for, much appreciated!
Art: I want to avoid re-engineering the P6B setup with a new non-boosted master cylinder if I can avoid it, its a 4 wheel disc brake setup and very good for its time... the electric motor making the suction looks like a simple solution
Fred: my manifold setup is literally individual runners and I dont want to start drilling/tapping that if I can avoid it. I appreciate that the Ford manifold pictured has this option, and apologies for the confusion, but my casting does not
Thanks to all who posted, very helpful!
Graham Ware
tr8todd
Todd Kishbach
(390 posts)
12/04/2009 07:42AM
Posted by: tr8todd
Date: November 02, 2013 04:27PM
[www.britishv8.org]
Lorenze doesn't run a booster on this car and it stopped just fine last time I drove it. FWIW, his car weighs over 3,000 pounds.
