WernerVC
Werner Van Clapdurp
Lynchburg, Va
(110 posts)
09/06/2009 12:56PM
MGB 1977 Rover 3.5
Steering like a truck
Posted by: WernerVC
Date: May 11, 2014 08:30PM
Has anybody tried to install a power assisted steering rack and what was the donor car ?
My mgb is hard to steer. thinking on installing power steering
(2631 posts)
Re: Steering like a truck
Date: May 11, 2014 08:59PM
Werner, Is everything greased up? A lot of guys do the caster wedges. There is an electric power steering unit that is spliced in under the dash and uses the stock rack. MR2 has a remote electric pump you can mount anywhere and use a Miata power rack like some of the more recent Cobra's. Do you have real wide tires in front? I thought about the Dodge Intepid center steer rack that is used in aftermarket swaps that never had power steering. David Townsend used the Dodge Omni rear steer rack on a mounting bracket. Do a search here and on Mgexperience board.
TNV8
Abe DeGraaf
TN
(46 posts)
10/18/2011 09:48AM
MGB 1980 Ford 302
Posted by: TNV8
Date: May 12, 2014 07:00AM
Try this link, he sells a kit.......
[thedrivenman.com]
Date: May 12, 2014 07:22PM
I've never found the B's steering to be heavy. Are you sure everything is in good repair?
