Richard/SIA
Richard Brengman
No. Nevada
(401 posts)
01/17/2014 07:47PM
Where to get decent 14" tires?
Posted by: Richard/SIA
Date: September 02, 2015 12:29AM
Getting a head-ache trying to search for decent tires in the 185/60 to 205/60-14 range.
Tire-Rack needlessly changed their site so that I can no longer compare by diameter, section and tread width.
Need to decide on tires in order to work suspension calculations.
Some sites are saying that the tire companies have abandoned the street performance market in 14".
(4636 posts)
Re: Where to get decent 14" tires?
Date: September 02, 2015 01:43AM
hmmmmm... Tire Rack lists Dunlop Direzza Star Spec ZII tires in 185/60R14 for $122 each.
(4615 posts)
Date: September 02, 2015 09:44AM
That is a great tire & pretty much is it for 14".
Richard/SIA
Richard Brengman
No. Nevada
(401 posts)
01/17/2014 07:47PM
Date: September 02, 2015 02:44PM
Found Toyo R888 205/55-14 but not sure I can get away with going that wide.
Picked up my book on suspension from storage so I can begin to set up the calculations.
Would be nice to have the stock GT6 measurements as a starting point.
I have chassis measurements but nothing that gives axle angles, upper and lower arm length, etc.
Should be able to find stock caster, camber, etc. in my manual.
(4615 posts)
Date: September 02, 2015 05:32PM
You do know that Toyo R888 a is low mileage competition tire meant for racetracks & autocross?
Richard/SIA
Richard Brengman
No. Nevada
(401 posts)
01/17/2014 07:47PM
Date: September 02, 2015 10:40PM
I saw that the Toyo is DOT rated so should be street legal.
Probably not going to put a lot of miles on this one as I'm looking to use it as a summer car and in a few local street speed events.
Being a closed car in the Nevada summer without AC, probably not the daily driver.
Will look into the Toyo durability.
Many years ago when much younger would occasionally run my Bug-Eye on cast-off race slicks for a weekend of mountain roads.
Richard/SIA
Richard Brengman
No. Nevada
(401 posts)
01/17/2014 07:47PM
Date: September 03, 2015 02:33AM
OK spoil-sports, I will play like an adult. (But not happily ;-P )
Looks like 185/60-14 it is.
Good availabilty so should remain viable for a while even if I eventually have to to to Goodrich as they seem to keep making the "old" sizes after others quit.
New things to look up or measure, Merkur XR4Ti hub parts, axle lengths, how to measure a CV axle for modeling.
At least this research cost nothing but time.
(4615 posts)
Date: September 03, 2015 11:46AM
Don't listen to me. I run on Toyo RA-1 & they are in the same category as the R888. ;)
Date: September 03, 2015 04:41PM
Do you get any wet weather traction Carl?
(1389 posts)
Date: September 04, 2015 05:26PM
I have the Toyo R888's on one of my Volvo's.
225/50/ZR15
The wear rate is as alarming as you would expect. But not too bad for a part time car.
Wet weather handling is a rather severe compromise. Might as well be on ice.
Dry road grip is amazing. They stick like s.... to a blanket.
(4615 posts)
Date: September 04, 2015 09:32PM
Rob,
They are supposed to be good for wet at full tread. I am on my second set, but have never had full tread. The first set I ordered shaved to 5/32". My current set I bought used at about 4/32". I am okay in a light rain. They hydroplane badly on a very wet road, as in slow down to 40 or so. Dry road? Like Fred said, they stick like nobody's business. :)
Richard/SIA
Richard Brengman
No. Nevada
(401 posts)
01/17/2014 07:47PM
Date: September 05, 2015 04:12AM
So then the question become how valuable is ultimate stickiness on a TR GT-6?
Rear suspension will be custom and optimized for handling.
Front may get changed out too, have not decided yet.
Ultimate stick, or powerslide, that is the question!
KadettB
David Stephens
SLC, UT
(10 posts)
07/14/2017 03:41PM
Absolutely original custom freak TBD, probably '98 Vortec 7400
Posted by: KadettB
Date: July 14, 2017 04:17PM
Corvette guys run the Toyo R888 on the street all the time. It makes a good 3-season tire as long as you always respect what you're driving on. It can't do any snow whatsoever, rain only when new and warm weather. No weather below 50*F. It's nearly as good as drag radials, but can corner way better.
Date: July 20, 2017 04:07PM
I have g-Force Rivals which are the same category. Damp roads are OK, but in pouring rain with a bit of standing water on the roads they hydroplane like crazy. For around town its not been a problem because slower speeds. But on a long drive (like the TX to WV trek for BV8) going 40 will put you way behind.
Edited 1 time(s). Last edit at 07/21/2017 07:38PM by rficalora.
Mickey Richaud
Mickey Richaud
Townsend TN
(198 posts)
08/25/2015 06:36AM
'03 Jaguar XK8 Jaguar 4.2
Posted by: Mickey Richaud
Date: July 20, 2017 05:00PM
Do you absolutely need the 60 profile? If not, Vredestein tires are quite good and there are several options offered in 14":
[www.tirerack.com]
(4615 posts)
Date: July 21, 2017 07:59PM
Well, since I still haven't decided on 15"wheels, I guess I will go with a real street tire in a 200 TW.
Since I can't really wait for Dunlop's new Direzza ZIII Star Spec that is only available in the Japanese market currently, probably going to go with Falken's new Azenis RT-615K+ in a 195/60-14.
[www.falkentire.com]
Scott68B
Scott Costanzo
Columbus, Ohio
(569 posts)
10/25/2007 11:30AM
1968 MGB GM 5.3 LS4 V8
Posted by: Scott68B
Date: July 21, 2017 10:39PM
I've been seriously looking at those too Carl.
(4615 posts)
Date: July 22, 2017 06:33PM
We run the Falken RT615K 205/50-15 on our TR6 ChumpCar race car.
http://www.britcars.net/TR6/Carl%20at%20VIR%203-4-2017.jpg
(4615 posts)
Date: October 10, 2017 12:08PM
For the MGB in a 14", looks like we are down to 185/60 or 195/60. Time to go 15" or 16"
[www.tirerack.com]
