exfed12825
Tony Gentile
Waterford, Pa
(61 posts)
03/30/2016 02:43PM
1974 MGB 347ci Bessel Motorsports/ Ford stroker 530 hp
Fluid Film
Posted by: exfed12825
Date: April 07, 2016 11:22PM
I'm planning on using Fluid Film on the Heim Joints on my Fast Cars inc MGB suspension any better choices for the lube
(1389 posts)
Re: Fluid Film
Date: April 08, 2016 10:09PM
Fluid film will work just fine.
You will need to apply it often as it's a little thin and tends to be pushed out of the joint.
I generally use moly chain lube in this situation. It's a heavy grease in a solvent carrier. It sprays on thin and works it's way into the joint, the solvent evaporates leaving a very durable moly grease film behind. It works well in lots of other applications as well, door hinges are my favorite!
The best way however, in my mind, is to seal the joints with urethane cups. I think Prothane makes them if I remember right. And drill them to take a grease fitting.
This keeps the dirt out and alows you to flush the joint with fresh grease from the inside out.
Live like you mean it.
(6585 posts)
Re: Fluid Film
Date: April 09, 2016 10:57AM
Fred, you have a link? I couldn't find those on their site.
(1389 posts)
Re: Fluid Film
Date: April 09, 2016 12:27PM
I put some on my Milano a while ago.
Pretty sure that there is a part # on them.
I'll jack it up on monday and have a look.
Nexxussian
Erik Johnson
Alaska
(62 posts)
04/20/2015 10:32PM
1974, MGB, Citroen Color Rover V8
Re: Fluid Film
Posted by: Nexxussian
Date: April 10, 2016 11:46PM
Urethane would be nice, but these work too.
[www.speedwaymotors.com]
(6585 posts)
Re: Fluid Film
Date: April 11, 2016 12:37PM
They sort of do. Easy for them to get damaged or in a position where they do not seal though.
(1389 posts)
Re: Fluid Film
Date: April 11, 2016 01:34PM
Got a look this morning
The number on the seals is 60461
From Prothane for sure.
(6585 posts)
Re: Fluid Film
Date: April 11, 2016 05:06PM
