Goto Page: Previous12
Current Page: 2 of 2
ghornbostel
Greg Hornbostel
Nebraska
(75 posts)
09/02/2013 01:41PM
1957 TR3 Buick 231 evenfire V6
Re: Ackerman settings on TR3
Posted by: ghornbostel
Date: November 08, 2018 12:48AM
As you can see from the bottom photo the inner and outer tie rod piviot points fall on a line between the upper and lower A arm piviot points. You can achieve this on the outer point with the stock drag link but not with the inners.
tbo
Tim Body
St Thomas Ontario
(205 posts)
01/27/2013 06:47PM
Posted by: tbo
Date: November 13, 2018 07:29PM
Greg . Thanks for the explanation. When I figure that out and understand it I will let you know . I get the drift but I wouldn't write an essay on it.LOL Tim
ghornbostel
Greg Hornbostel
Nebraska
(75 posts)
09/02/2013 01:41PM
Date: November 18, 2018 11:12AM
Tim, to begin with I replaced the drag link with a adjustable link with heim ends. That enabled me to change the inner tie rod pivot point position. Ended up with drag link on bottom and tie rod on top of stock arms with spacers under heim ends to eliminate bump steer. Not liking the stress of the drag link and tie rod on the same bolt I fabricated the arms in the photos. Thinking this over now it would probably be possible to fabricate the arms to use stock tie rod ends for a more stock appearance. It is what it is for now.
