ghornbostel Greg Hornbostel Nebraska (76 posts) Registered: 09/02/2013 01:41PM Main British Car: 1957 TR3 Buick 231 evenfire V6 |
Re: Ackerman settings on TR3
As you can see from the bottom photo the inner and outer tie rod piviot points fall on a line between the upper and lower A arm piviot points. You can achieve this on the outer point with the stock drag link but not with the inners.
Greg . Thanks for the explanation. When I figure that out and understand it I will let you know . I get the drift but I wouldn't write an essay on it.LOL Tim
Tim, to begin with I replaced the drag link with a adjustable link with heim ends. That enabled me to change the inner tie rod pivot point position. Ended up with drag link on bottom and tie rod on top of stock arms with spacers under heim ends to eliminate bump steer. Not liking the stress of the drag link and tie rod on the same bolt I fabricated the arms in the photos. Thinking this over now it would probably be possible to fabricate the arms to use stock tie rod ends for a more stock appearance. It is what it is for now.
