exfed12825 Tony Gentile Waterford, Pa (61 posts) Registered: 03/30/2016 02:43PM Main British Car: 1974 MGB 347ci Bessel Motorsports/ Ford stroker 530 hp |
List of EPS Units
Below is the list of cars that have Fail-Safe Electric Power Steering columns, this means that Only 3 wire connection. Ignition On, Power and Ground to the Steering ECU. That's it ! These units will run in limp mode, which is a power assist that is more than enough to supply power steering to the light weight of our little hot rods, and if there is a full failure revert back to your original manual steering
2004-2009 Toyota Prius 2009-2013 Toyota Corolla 2006-2011 Toyota Yaris - (With ABS) 2007-2009 Nissan Versa 2009-2012 Nissan Cube 2012-2014 Kia Soul ECU Part Numbers: 2004-2009 Toyota Prius 89650-47102 2009-2013 Toyota Corolla 89650-02300 2006-2011 Toyota Yaris - (With ABS) 89650-52120 / 52050 2007-2009 Nissan Versa 28500-EM30A / 991-30303 2009-2012 Nissan Cube 28500-1FC0B / JL501-000932 2012-2014 Kia Soul B2563-99500 / 4PSG1312 / FPSG1312 I pulled this list off of the forum "For A Bodies Only" and a post by waid302, Below is a direct link to this post [www.forabodiesonly.com] |
Re: List of EPS Units
That's a pretty handy little list Tony!
Thanks Fred |
I'm looking at the 2009 -2013 Toyota Corolla unit, I can't remember where I saw it but there was a picture of one next to a 16 oz beer can and they were about the same size. This unit seems to take up the least amount of under dash room. It also seems to be the most available and runs between $80 and $200 on ebay
Edited 1 time(s). Last edit at 03/20/2017 07:54PM by exfed12825. |
Actually, we already have that link on page 8 of the big Electric Power Rack Steering thread that has been running 6.5 years.
Good that you copy/pasted the list, Tony. We will still have the info if the link goes dead. |
Here is a link to the installation instructions for the Toyota Yaris ServTronic.com EPS module with GPS.
[drive.google.com] You can purchase the modules direct www.ServTronic.com Edited 1 time(s). Last edit at 05/12/2025 01:24PM by v8mgb. |
AKA: Bruno Box. We've installed two of these GPS units and one of the originals with good results and have also done one 'bare' install with no module and did not find it necessary to adjust the midrange although I'm not positive, Dan may have adjusted his in his TR7. The bare install ends up with a delay of a second or so before the boost comes on but otherwise is a great improvement. The Bruno box gets rid of the delay and I think the GPS one is more immediate than the non-GPS. Typically the antenna is adhered to the panel between the windshield and the dashboard.
One characteristic of the upgrade to EPS is that you lose most of the MG's characteristic steering return-to-center due to the resistance of the gears and drive motor and if this is a greatly desired trait some of it can be gotten back by increasing camber and/or installing roller thrust bearings in the kingpins. Eventually I expect to get back to work on a kingpin/timken conversion but probably not this year. Jim |
