(5729 posts)
Source for brake M/C
Date: June 10, 2018 08:06AM
The Mark-I MGB used a metal canister type 3/4" bore M/C, the early Spitfire used the same M/C with an 11/16" bore.
I need one with a 5/8" bore.
Does anyone know what car that was used in?
ex-tyke
Graham Creswick
Chatham, Ontario, Canada
(1046 posts)
10/25/2007 11:17AM
1976 MGB Ford 302
Re: Source for brake M/C
Posted by: ex-tyke
Date: June 10, 2018 10:04AM
Might try Wilwood
[www.ebay.com]
[www.ebay.com]
Lots of motorcycles use 5/8"bore cylinders but might not be configured right for your application.
Austin Mini had a .70" bore master.
Edited 1 time(s). Last edit at 06/10/2018 10:50AM by ex-tyke.
(5729 posts)
Date: June 10, 2018 12:32PM
Thanks Graham, that'll be the last resort as I'd have to reconfigure the line(s) and I'd rather have matching M/C's. My balance bar needs a little help as it is at the end and still needs more.
I'd like to stick with the tin-can reservoir OEM type if I can find one. The Mini is a little closer than the Spitfire/Midget one but my calculations indicate the 5/8" would be a better match.
ex-tyke
Graham Creswick
(1046 posts)
10/25/2007 11:17AM
1976 MGB Ford 302
Posted by: ex-tyke
Date: June 10, 2018 12:55PM
Might investigate re-sleeving your 3/4" M/C and getting a 5/8 rebuild kit and piston.(you're good at lathe work)
Do it yourself or have White Post do for you.
[whitepost.com]
Edited 1 time(s). Last edit at 06/10/2018 12:58PM by ex-tyke.
(5729 posts)
Date: June 10, 2018 01:05PM
Actually that was wrong, the 11/16 bore is less than .700" so the Spitfire M/C would be better than the Mini.
But my guess is that an earlier car, maybe something pre-disc brake would have used a 5/8" bore.
(3601 posts)
79 MGB, Buick 215
Date: June 10, 2018 01:14PM
geezer
Charles Durning
Magee, MS
(45 posts)
11/16/2017 01:16PM
1974 MGB, 1967 Morris Minor
Posted by: geezer
Date: June 11, 2018 11:26AM
Jim,
You might look into a clutch master cyl from a Midget, Sprite, or a Spitfire. If memory serves me they are smaller than the brake cyl.
(5729 posts)
Date: June 11, 2018 02:15PM
Yes, they are 11/16". I need 5/8"
ex-tyke
Graham Creswick
(1046 posts)
10/25/2007 11:17AM
1976 MGB Ford 302
Posted by: ex-tyke
Date: June 11, 2018 05:39PM
I assume that you want a dual circuit M/C (rather than a single)
Might not be anything out there that small ......I still maintain that sleeving is a viable option.
(5729 posts)
Date: June 11, 2018 08:02PM
Actually Graham I'm looking for a single circuit M/C and would also consider a clutch M/C. I have a twin master/balance bar setup, with dashboard adjustment knob. Currently both M/C's are 3/4" bore just like the mark I and II cars use.
Apparently the Minx used a 5/8" M/C for the clutch which I think would work, Lockheed No. 4223-917 Where to get a new one is the question.
ex-tyke
Graham Creswick
(1046 posts)
10/25/2007 11:17AM
1976 MGB Ford 302
Posted by: ex-tyke
Date: June 11, 2018 08:34PM
If your looking for a basic single circuit master, check the Dorman website for clutch masters . Here's one 5/8" bore example for a Ford Courier.
[www.dormanproducts.com]
Edited 1 time(s). Last edit at 06/11/2018 08:41PM by ex-tyke.
(5729 posts)
Date: June 12, 2018 08:34AM
That Dorman does look pretty good. I've sent Kelvin a note to see if maybe Moss might have the Minx part. If not I may have to go with one of those types.
geezer
Charles Durning
Magee, MS
(45 posts)
11/16/2017 01:16PM
Posted by: geezer
Date: June 12, 2018 10:40AM
Subaru uses a 5/8 clutch master
[www.rockauto.com]
From a Mazda
[www.rockauto.com]
Edited 1 time(s). Last edit at 06/12/2018 10:45AM by geezer.
ex-tyke
Graham Creswick
(1046 posts)
10/25/2007 11:17AM
1976 MGB Ford 302
Posted by: ex-tyke
Date: June 12, 2018 12:04PM
Could try these guys...
[www.powertrackbrakes.co.uk]
(5729 posts)
Date: June 12, 2018 04:20PM
Thanks Graham, I just sent them an email.
Moss has the .700" one for the midget.
(1953 posts)
Date: June 12, 2018 04:48PM
The Datsun/Nissan Z master:
[www.ebay.com]
(5729 posts)
Date: June 15, 2018 03:09PM
Got one coming from UK. NOS, hopefully get here in the next couple weeks.
ex-tyke
Graham Creswick
(1046 posts)
10/25/2007 11:17AM
1976 MGB Ford 302
Posted by: ex-tyke
Date: June 15, 2018 03:44PM
Application?....photo?....inquring minds need to know!
(5729 posts)
Date: June 16, 2018 10:11AM
I'll post a photo when it gets here but as far as I can tell it looks just like the early MGB round tin can master. (or clutch M/C which is what it is) May be zinc galvanized rather than cadmium chromated.
Application is Rapier Minx, part number is Lockheed AP # 4223 - 917.
No longer being made according to one source. N.O.S. like I mentioned, no idea how many are left. My guess, not many.
