Goto Page: Previous12
Current Page: 2 of 2
ex-tyke
Graham Creswick
Chatham, Ontario, Canada
(1024 posts)
10/25/2007 11:17AM
1976 MGB Ford 302
Re: Proper tightening of FastCars IFS spindle nuts
Posted by: ex-tyke
Date: July 08, 2018 02:35PM
Wasn't the Fast Cars front axle based on a BMW series 3 design?
(2529 posts)
Date: July 08, 2018 02:58PM
Geometry yes. Parts apparently not.
(2529 posts)
Date: July 08, 2018 04:32PM
Progress, but no cigar yet. Got seals that'll work. National 1174. Slightly thicker, but there's room on the shaft for that. Outer bearing looked brand new. Inner, now that I pulled the seal and got a look at it, not so much. And, my (bad) luck is holding... PN I have is LM1179 which parts houses are saying doesn't show in their systems and I've not found it on line. Awaiting Terry to see if I have the wrong #?
Anyone else know a good PN for the inner bearing?
Told my folks I'd not be coming today so if I can't get bearings today, I should be able to tomorrow.
Getting there, one step at a time.
(2529 posts)
Date: July 08, 2018 11:52PM
Terry returned my text. PN was wrong; car's back together and loaded to go.
ex-tyke
Graham Creswick
(1024 posts)
10/25/2007 11:17AM
1976 MGB Ford 302
Posted by: ex-tyke
Date: July 09, 2018 07:32AM
Padgettsolutions
Monte Padgett
(6 posts)
04/11/2018 04:44PM
Posted by: Padgettsolutions
Date: July 20, 2018 09:55AM
A trick I have learned over the years when looking for grease seals. Measure then OD of the shaft the seal rides on.
The diameter of the shaft will be close the part number. ( This was true for National/CR seals) Example a 2.137 diameter shaft would have a seal number of 2137XX.
