tr8todd
Todd Kishbach
(349 posts)
12/04/2009 07:42AM
TR8 5 lug aluminum hubs
Posted by: tr8todd
Date: February 22, 2019 03:06PM
I'm tossing around the idea of having a machinist make me up some hubs out of 6" round stock 6061 aluminum. Not entirely happy with the trailer hubs I mocked up. Too many spacers to inspire complete confidence that everything is going to hold together at very high speeds. Thinking about making hubs that are fairly close to TR8 hubs except the brake rotors will fit on the front of the hub instead of bolting to the back. 5X4.5 wheel bolt pattern to match the common Ford pattern. This will allow narrowing a Ford 8.8 without ordering custom axles, and will open up a wider selection of aftermarket wheels. I can either have him make me a couple of sets in the lathe, or I can try and find somebody with a CNC machine. The CNC set up is only worth it if somebody other than me wants these things. Once its programmed, he can run off as many as I want. Material costs should only be about $50 a piece, plus bearings and studs. Is there anybody, other than me, that has any interest in this? For me, its an easy button to solve all of my wants in the best way. Light weight aluminum hubs, with the correct offset, set up for Wilwood aluminum hats and vented rotors.
WernerVC
Werner Van Clapdurp
Lynchburg, Va
(90 posts)
09/06/2009 12:56PM
MGB 1977 Rover 3.5
Re: TR8 5 lug aluminum hubs
Posted by: WernerVC
Date: February 27, 2019 10:28PM
Hi Todd,
Can you give some more details about the 5 lugs hubs ?
I have a set of vintage Maxilite wheels that I want to install on the rear end of my MGB. So I am very interested if you can get the 5-lug hubs. The bolt pattern must be 120 mm. These rims are brand new, never used and would fit for a Jaguar. Same bolt circle as Chevrolet.
Let me know about that project asap. More details on rotors and set up please.
Werner
(2972 posts)
Aluminum Front Hubs
Date: February 28, 2019 11:35AM
I like the series II RX7 hubs, light, strong design with adequate bearing/spindle sizes. Art.
(5720 posts)
Re: Aluminum Front Hubs
Date: February 28, 2019 12:12PM
How about some details on those Art?
(2972 posts)
Date: March 05, 2019 05:42PM
Deep cross section like Porsche, only Japanese cheap,(many produced). I used larger shoulder, 1/2-20 studs to arrive at 5 on 4.5" bc. Art.
(5720 posts)
Date: March 06, 2019 01:07PM
Good. Is it a direct fit on the MGB spindle? Does it use the same offset? Can it be used for chevy pattern as well? (5 on 4.75")
WernerVC
Werner Van Clapdurp
Lynchburg, Va
(90 posts)
09/06/2009 12:56PM
MGB 1977 Rover 3.5
Posted by: WernerVC
Date: March 08, 2019 08:39PM
Jim,
I am fighting the same battle. Hope to find 5-lug spindles that fit the MGB spindles. Too bad the MGC spindles are a very rare beast.
That would be a perfect fit.
Hope to get an answer soon from Art.
Werner.
PS.: I have a set of new Maxilite rims with bc of 120 mm used for a jaguar. Cannot find nuts for it. Anyone has a source for it. I need 15 of them . Nuts have 1/2" threads and shank is 3/4 "
(1953 posts)
Date: March 11, 2019 06:11AM
The RX7 hubs use straight cartridge bearings. I remember that Art bored them out for Mustang II or GM bearing races. Mid 80's Series II N/A had 4 lug same as MGB and Turbo had 5 lug Ford pattern.
Edited 1 time(s). Last edit at 03/11/2019 06:12AM by mgb260.
