Jim Stabe Jim Stabe San Diego, Ca (779 posts) Registered: 02/28/2009 10:01AM Main British Car: 1966 MGB Roadster 350 LT1 Chevy |
Re: Power Brake Boosters
I ran across this on the internet this morning. [brakepower.com]
BlownMGB-V8 Jim Blackwood 9406 Gunpowder Rd., Florence, KY 41042 (5989 posts) Registered: 10/23/2007 12:59PM Main British Car: 1971 MGB Blown,Injected,Intercooled Buick 340/AA80E/JagIRS |
The booster itself is a vacuum canister, and should hold enough for one or two boosted applications, maybe more depending on how hard you hit the pedal. An aux canister will add more uses between. You can base the size on the booster itself.
MGBV8 Carl Floyd Kingsport, TN (4014 posts) Registered: 10/23/2007 11:32PM Main British Car: 1979 MGB, Buick 215 |
Yeah, a reserve canister is not going to help an engine with low vacuum to begin with. I guess that means using an electric vacuum pump, like Bill suggested.
Here is a Brake Bias calculator to go with the one Jim S. posted. [www.tceperformanceproducts.com] |
This is the calculator I used to design my brake system. It is an Excel spreadsheet so I couldn't post mine on this site but you can download it - it is the attachment in the first post. I like this one because it takes center of gravity height into account as weight is transferred during a stop. It came out pretty much on the money for my car.
[locostusa.com] |
88v8 Ivor Duarte Gloucestershire UK (819 posts) Registered: 02/11/2010 04:29AM Main British Car: 1974 Land Rover Lightweight V8 |
My TR6 with its big cam, made 7" at idle. And it does matter, because if you're tootling down the high street at pretty much idle, that's how much vacuum you have when some pedestrian walks out in front of you.
So I fitted an electric vac pump and a vacuum switch, gave me 19". Worked well for the five years I ran the car. Ivor |
Thanks for the link on that spreadsheet. After inputting values it is obvious from the results that I have a problem in the front calipers. Must be some stuck pistons, blockages, or something. Didn't think it was working the way it should.
Finally went out & measured the vacuum on my engine. Warmed up, it pulls 17" with an occasional dip to 16". When I reve the engine to 2500rpm or so & let off, it jumps to 21". That seems pretty normal at my altitude of 1450'.
The MGC, over the years, had a number of different booster ratios available ranging from 1.6 to 3.0. Rather than changing my booster to something else, I would like to source a stock size booster with a higher boost ratio. If, there is such a thing. Hmm.... Quote: |
mgb260 Jim Nichols Sequim,WA (2068 posts) Registered: 02/29/2008 08:29PM Main British Car: 1973 MGB roadster 260 Ford V8 |
Carl, Yep, that is the one. I looked everywhere except page one on this thread. Speedway has them:
[www.speedwaymotors.com] Edited 1 time(s). Last edit at 04/12/2019 01:11AM by mgb260. |
Helpful video on that link too. Not too long.
So to be clear, the advantage of the dual diaphragm is that it doubles the pressure applied to the M/C? (for the same booster diameter) Jim |
I don't think it doubles, Jim. Just eyeballing the 7" dual booster, the front diaphragm looks to be a good bit smaller than the rear.
Not much info out there on actual booster ratios. Did find this on Ebay: "A 7" Dual booster gives you 27% more stopping power than a 7" single" I think the MGB booster is a 6", so a 7" dual booster should be quite an improvement. Edited 2 time(s). Last edit at 04/13/2019 11:45AM by MGBV8. |
Well, I'll tell ylou something about boosters you probably already know; they can leak.
The Bendix Hydro Vac on my Rambler had 56 years in service, it was working, but I thought it was time for a refresh, so I sent it for rebuild. On return, they mentioned that it had a big vacuum leak and on their test rig it didn't work at all. Now, their test rig doesn't have a 327 vacuum pump, so it was working on my car. And even with the engine off, it held some vacuum. But as I now realise, it wasn't working very well. The brakes now are a lot sharper. And, I've had an intermittent problerm where the engine won't idle. Happened after a long run when it was thoroughly hot. Couldn't find any cause, thought it was bad petrol. And. it used to pink on acceleration even though the timing is correct,. Now, both those problems have gone. Cause? I guess, the vacuum leak. The more stuff you have, the more there is to go wrong. Ivor Edited 1 time(s). Last edit at 04/25/2019 04:20AM by 88v8. |
302GT Larry Shimp (218 posts) Registered: 11/17/2007 01:13PM Main British Car: 1968 MGB GT Ford 302 crate engine |
I bought the dual diaphragm booster from Speedway referenced earlier in this thread and installed it along with a new master cylinder (the master cylinder was needed because the stud spacing is much wider than the MGB master cylinder hole spacing). The boost is much more effective than stock, pedal effort is far lower but the brake feel is still very progressive.
The booster fits the MGB location without modifying the mounting surface. However, for ease of installation (relative) I shortened the mounting studs on the booster so that the retaining nuts could be tightened with a 1/8 inch drive ½ inch socket. I also had to make a clevis to adapt the booster input push-rod to the MGB brake pedal. The booster push-rod is threaded 3/8-24 and clevises fitting that are way too big. I made the clevis from 1/8 inch thick, ¾ inch wide bar stock. I bent it around a 3/8 inch bolt (to get the proper spacing), welded a 3/8 stop nut to the end, then drilled through the clevis and threaded it 3/8-24, starting the tap in the stop nut. To finish, I drilled the clevis for the brake pedal pin, then compressed the ends in a vise so that the cotter pin would go in the end of the pedal pin. I also shortened the booster push rod as needed. The master cylinder fits on the booster with no clearance problems with the hood. Plumbing was simple because I have 4 wheel disk brakes and had no need for proportioning valves or pressure retention valves. But there are many master cylinder options besides the Wilwood cylinder I used. Just about any GM, Ford, or Chrysler cylinder will bolt up to the booster and these are available for disk/drum configurations with built-in pressure retention valves for the drum circuit. I do not know if these alternative master cylinders will fit in terms of hood clearance, but for reference the Wilwood cylinder I used is 8.15 inches long, 3.22 inches high from the center of the bore, and 3.14 inches wide at the reservoir. The widest part of the reservoir is about an inch from the side of the engine compartment and the height of the front of the reservoir is about equal to the top of the channel containing the fender bolts. Note: the Wilwood master cylinder came with a push rod extension that goes between the booster and master cylinder. This may be needed but not included with a different master cylinder, but the extension rod is available separately from Wilwood. |
Pretty clean install Larry, worth keeping in mind.
