302GT Larry Shimp (218 posts) Registered: 11/17/2007 01:13PM Main British Car: 1968 MGB GT Ford 302 crate engine |
Re: Power Brake Boosters
I have now driven a few hundred miles with the new booster and I can report that it works even better than I expected. It allows the true power of the Wilwood front brake conversion to be realized. Pedal effort is low, very much like any modern car, but the brakes are easy to modulate. The highest speed stop I have tried was from 90 mph and it was effortless. This is almost a bolt in conversion with only minor fabrication needed, and probably has the biggest improvement vs time or cost of anything that can be done to an MGB. I am hoping someone who already has the stock MGB booster tries this and provides an independent assessment of the advantages...
MGBV8 Carl Floyd Kingsport, TN (4014 posts) Registered: 10/23/2007 11:32PM Main British Car: 1979 MGB, Buick 215 |
Thanks for the update, Larry!
I plan to, maybe this Fall. Do you think it would provide similar results with the OEM master cylinder size? |
With a smaller bore master cylinder the booster will appear to be even more powerful but there would be a somewhat longer pedal travel than what I have. However, if you have stock brakes pedal travel will be stock, but I assume you have upgraded brakes...
In any case, you will need a new master cylinder since the MGB cylinder flange is too narrow. |
I may have had them turned once in 1991. I need to measure them again. I'm sure they are at or below minimum specs by now.
