waterbucket
Philip Waterman
England
(77 posts)
07/30/2011 01:08PM
1978 MGB GT
Dropped spindles
Posted by: waterbucket
Date: July 09, 2019 03:42PM
I am progressing slowly with my engine swap and although not ready to do it yet am thinking about the front suspension. I have a rubber bumper crossmember in a chrome bumper bodyshell mostly for sump clearance and I have one! My thoughts were to use dropped spindles to get the front level with the rear while maintaining suspension travel in bump. I have emailed Dave Headley and he suggests that in a wet climate the loss of water seals on the kingpin makes it inadvisable to use them and to use the chrome bumper front end. That amount of chopping to the crossmember in the UK is a no no so does anyone have a solution?
ex-tyke
Graham Creswick
Chatham, Ontario, Canada
(1074 posts)
10/25/2007 11:17AM
1976 MGB Ford 302
Re: Dropped spindles
Posted by: ex-tyke
Date: July 10, 2019 09:17AM
Quote:
... the loss of water seals on the kingpin makes it inadvisable to use them...
My drop spindles and steering arms (pictured) came from Dick Luening (Killer Beez Racing)
Not sure what Dave is alluding to as far as loss of water seals – Dick’s MGB kingpin assemblies, reworked to lower/raise the spindle, retain all the existing original MG components. The drop steering arms still accommodate the original tie rod joints and seals. – not sure if Dave’s kingpins are manufactured differently to preclude original components.
(3708 posts)
79 MGB, Buick 215
Date: July 10, 2019 10:30AM
"not sure if Dave’s kingpins are manufactured differently to preclude original components. "
Yes, they are. I would prefer Dave's because he says they induce camber gain, but he does them differently & they do not have the top seal. They are mainly for racing.
If you absolutely cannot use the CB crossmember, Philip, get your dropped spindles from Dick Luening.
[mgbracing.com]
Are you absolutely sure the CB crossmember will not work? I have the RB crossmember & there is plenty of room under the oil pan (Buick 215) with the A/C set back engine mounts. I know of conversions that used the CB crossmember in a RB B. I may switch to a CB crossmember, myself.
302GT
Larry Shimp
(195 posts)
11/17/2007 01:13PM
Posted by: 302GT
Date: July 12, 2019 07:54AM
Dave's drop spindles use king pins that are longer than stock. They are assembled with the spindles and then are welded together in place. To replace the bushings the assemblies need to be sent back to Dave to be cut apart, new bushings put in, and king pins rewelded. Dick's spindles use stock king pins and are serviced exactly the same as the stock assemblies.
Because Dave's drop spindles are taller than stock, the upper A arms are angled up compared to the lower A arms, and this is what induces camber gain.
jjohanski
James Johanski
(25 posts)
11/15/2017 08:57AM
Posted by: jjohanski
Date: July 14, 2019 07:40AM
I am using Dick's dropped spindles and they have the stock seal set up.
(3708 posts)
79 MGB, Buick 215
Date: July 15, 2019 05:46PM
Sadly, Dick Luening,passed away last month.
Not sure if his 2 sons are planning to continue the business.
jjohanski
James Johanski
(25 posts)
11/15/2017 08:57AM
Date: July 16, 2019 07:28AM
Carl, I did not know that Dick had passed. He was a wonderful honest man that I knew for over 40 years. I first met him racing at Blackhawk farms in Southern WI in the early 70's. Last time I saw him was about five years or so ago at the All British Swap meet at DuPage County Fairgrounds. He loved his family and especially the grand children. Some may know that he built an MGB V8 for his daughter. Hope his sons carry on but the trade is getting smaller and failing, so it will be hard. I guess the problem is dying. RIP Dick.
40indianss
don foote
(51 posts)
08/01/2013 04:35PM
Posted by: 40indianss
Date: July 16, 2019 12:39PM
Seems as if the seal or lack of could be mitigated by maintenance on a regular schedule and possibly using the blue boat trailer wheel bearing grease which is stickier than snot and seems to work well for boat trailers in salt water environments
waterbucket
Philip Waterman
England
(77 posts)
07/30/2011 01:08PM
1978 MGB GT
Date: July 16, 2019 07:08PM
Carl
I am fitting the Jaguar AJV6 engine with a Mazda RX8 gearbox into a chrome bumper bodyshell. By using the combination of a Mondeo (Contour?) ST220 sump which has the lowest front section and a larger oil capacity I am able to get this under a stock bonnet only by using a rubber bumper crossmember. This is a condition of my wife, no warts on the bonnet! The engine fits into the chrome bumper bodyshell with no mods except through the fender headers and removing about an inch off the top of the crossmember.
I am trying to get down to CB ride height at the front without reducing bump suspension travel and the dropped spindles seemed the ideal way until Dave Headley put me off the idea, another honest guy who could have sold me the spindles and said nothing.
Edited 1 time(s). Last edit at 07/16/2019 07:17PM by waterbucket.
(3708 posts)
79 MGB, Buick 215
Date: July 17, 2019 12:30PM
If a CB to RB crossmember did the job, the best solution would be to notch the CB crossmember for clearance?
If not interested in that maybe you can still get the other dropped spindles from MG Limited.
[mgbracing.com]
Dave Headley's take on the dropped spindle does not bother me. I run in the dry most of the time & on good roads. More frequent grease job & I think it will be fine.
40indianss
don foote
(51 posts)
08/01/2013 04:35PM
Date: July 17, 2019 11:41PM
My point exactly on the boat trailer wheeli bearing grease and frequency of maintenance. Should be nothing to worry about and I am also using dave headley's spindles
Edited 1 time(s). Last edit at 07/17/2019 11:46PM by 40indianss.
waterbucket
Philip Waterman
England
(77 posts)
07/30/2011 01:08PM
1978 MGB GT
Date: July 18, 2019 02:13AM
Carl
It is not only swapping crossmembers but notching them as well, a RB one by an inch CB one by two inches. The problem we have over here is that we have to have an annual test (MOT) for modified classic cars unmodified do not, if the tester notices any modification to the monocoque or a number of modifications to other areas he has to refer you to the DVLA, they will then automatically demand an IVA test (type approval). I can lower a RB crossmember by an inch and ny smoothing the shape and grinding the welds smooth it is very unlikely anyone would notice. The through the fender holes can be argued factory original.
As to why a Jaguar AJV6 engine, then why not? In its favour apart from height it is reasonably light at 360lbs and a compact 20 inches long. A healthy 240 bhp from a free revving engine. In fact the height issue is not too bad, It will fit under a standard bonnet with no other mods, similar to the GM X30XE that Ian Cass is doing.
Why not a Rover V8? Well over here they are becoming expensive, I think more so than with you. By now a large proportion are high mileage and even the lower mileage ones will need rebuilding, the typical cost for a rebuilt long block is £4000 , Mnual gearboxes and bellhousings are also becoming scarce and expensive. We do not have easy access to 0.68 or 0.73 T5's so we have to change the rear axle anyway or have a 22MPH top gear.
The GM X30XE in comparison can be bought with a gearbox and an ECU which will run without mods for a similar cost to a second hand bellhousing for a Rover V8!
The greasing does not bother me, every week I am under my work machine, 12 nipples every time. I did not know about the trailer grease, in the past I have watched boats launching into the sea and wondered how they got away with salt water in the bearings, now I understand
(3708 posts)
79 MGB, Buick 215
Date: July 18, 2019 03:07PM
"The through the fender holes can be argued factory original. "
Not sure how that is done successfully. Are you a lawyer? ;)
waterbucket
Philip Waterman
England
(77 posts)
07/30/2011 01:08PM
1978 MGB GT
Date: July 19, 2019 02:18AM
The MGOC and the DVLA had an "understanding" that as MG made the RV8 with those holes and Heritage manufacture complete new rubber and chrome bodyshells with them it was acceptable to make them yourself. If challenged by a difficult DVLA person it might be nigh on impossible to win the argument though.
(5799 posts)
Date: July 19, 2019 11:04AM
Wasn't there something about the geometry changes that are caused by dropped spindles? Seems like I heard that but can't remember what exactly the issue was.
(3708 posts)
79 MGB, Buick 215
Date: July 19, 2019 11:36AM
Worst I have heard is increased bump steer that is corrected with bent steering arms.
Glad you have the RV8 loophole, Philip. Surprising, though, since it was built by Rover 12-13 years after the MGB was laid to rest & hardly any, if any, parts interchange. I won't tell 'em, though. ;)
