(4615 posts)
IRS Vs Solid Axle
Date: May 03, 2023 09:18AM
Interesting...
[grassrootsmotorsports.com]
Airwreckc
Eric Cumming
RTP, North Carolina
(253 posts)
05/28/2020 10:10AM
Re: IRS Vs Solid Axle
Posted by: Airwreckc
Date: May 03, 2023 12:48PM
Good to know--makes me feel better about using my Ford 8". Thanks for posting, Carl.
(6569 posts)
Date: May 04, 2023 07:25AM
Depends on what you are after. generally the solid axle will be better for straight line acceleration and the IRS will be better on uneven or rough road surfaces.
(4615 posts)
Date: May 04, 2023 10:14AM
I agree with the author. I do not believe that the IRS is superior on a road course.
(6569 posts)
Date: May 04, 2023 04:18PM
I guess it depends...
ag1234
Arthur Gertz
(158 posts)
03/29/2023 08:26PM
Posted by: ag1234
Date: September 03, 2023 12:01PM
So , are most of us, using our cars primarily for road courses ? Sounds like roads in many states are becoming 1,5 caca ? How do you get a good camber curve on a solid axle ?
Art.
(4615 posts)
Date: September 04, 2023 09:39AM
Street cars will have compromises & with IRS squat & dive things are constantly changing. I am certain that designing a good IRS is a giant PITA.
On the other hand my B has little body roll & not that much suspension travel. So, the camber gain is not much of an issue. I prefer the simplicity of the live axle.
(6569 posts)
Date: September 05, 2023 07:38AM
Certainly a live axle is much less expensive and much simpler to implement than a well designed IRS, and one that squats on launch is not that well designed. Squatting means that the axle is lifted, a thing that does not contribute to maintaining tire contact. Drag racers lift the rear on launch to put more initial pressure on the tire patch, but much more commonly body height is unchanged. The TR4/6 is a notable exception.
IF the IRS is restricted in travel as the stock axle sometimes is with lowered ride height, stiff springs and shocks there may not be much of a noticeable improvement. However if the install is done in such a way to take advantage of what the IRS has to offer the results can be significant. It may take some time to tune the suspension and achieve these results.
I feel I have accomplished this now with the MG-Roadmaster and my roadster using the narrowed Jag IRS and the widened bodywork.
Carl will be driving the RM this coming weekend to attend the GCBCC show and will have the opportunity to evaluate all aspects of the car including the handling and I look forward to his feedback. The car is not fitted with sticky tires like his so it won't be any sort of direct comparison but it should be interesting nonetheless. I do have a couple of twisty local roads I can show him.
ag1234
Arthur Gertz
(158 posts)
03/29/2023 08:26PM
Posted by: ag1234
Date: April 01, 2025 12:14PM
Grassroots ignores the benefits of camber curves and low unsprung weights on bumpy roads.. Use aluminum Dana 36 of 44/ Vette with its connectors/ geometry =good to go.
Art.
(1389 posts)
Date: April 10, 2025 03:19AM
Just an FYI.
It is very easy to get a negative camber from a live axle.
Many of us old racers have done it since god was little.
You simply bend the housing, some axles will give you up to a degree of negative camber with no issues at all.
It sounds haywire beyond belief but it works very well. A worn set of side gears are your best friend.
My P1800 ES has been run that way for 20 odd years or so with no issues.
Makes the tire guys with the free alignment checks freak out though.
Live like you mean it.
