Med72 Art Medrano Austin, Tx (52 posts) Registered: 01/31/2012 09:25PM Main British Car: 1972 Triumph TR6 GM 350 |
Narrowing a Mustang II Rack and Pinion
After a long hiatus I am back working on my TR6. I complete the frame to accept an LS using a Mustang II suspension that I narrowed 5.5 inches. I need to install a R&P that is narrow proportion to new length of my front suspension. Exactly 5.5 inches. I have contacted a bunch of machine shops here in Austin but no one has or does this type of work.
Does anyone have any ideas where I could send my rack and pinion or where I could buy a R&P that will work with my modified suspension? |
Re: Narrowing a Mustang II Rack and Pinion
Fatman and Flaming River sell shortened racks and can shorten yours. Or you could find a shorter rack from a small car.
Or do your own: [www.yellowbullet.com] Edited 2 time(s). Last edit at 05/30/2023 03:29PM by mgb260. |
I read the stream from the yellowbullet website. If i understand this correctly, they detached the right side of the R&P by unscrewing the pivot housing attached to the arm and they cut down (shorten) the housing correct? That is how I see it as well. My problem is I cant find anyone to machine (lathe) the shaft.
I will give a shout to FR to see if they can help me. thanks |
