302GT Larry Shimp (245 posts) Registered: 11/17/2007 01:13PM Main British Car: 1968 MGB GT Ford 302 crate engine |
GT rear tie bar
The GT body is as strong or stronger than the roadster body in all aspects except for the area between the rear wheel wells. The roadster has the trunk wall there, and the body passes closely above. But there is just empty space in the GT. This area can be reinforced by making a simple tie bar that goes between the seat belt mounting points at the tops of the wheel wells. The easiest approach is to use a 1 1/4 in, 1/8 inch thick steel angle piece that is available at any home supply store.
I tried this on my car and it seems to make a difference (but I may be biased). I suspect it might be most useful on GTs with a panhard rod or a coil spring conversion. But it is such a simple thing to do, there is really no reason not to try it on any GT. |
Re: GT rear tie bar
Makes sense - like a strut tower brace. Think a bar across the "frame" rails or higher - like you find on typical 4-link set ups would serve the same purpose - or not located high enough to prevent or limit any motion?
Re: GT rear tie bar
Larry, you've got to post a picture!
Reinforcing this area makes perfect sense to me too... although a piece of tubing might be even better than angle (by virtue of spreading out the weld area and being more resistant to flexing/buckling). This, on the other hand, is probably overkill: [www.britishv8.org] |
Re: GT rear tie bar
A photo is attached. I used square tubing, but that took some fabrication. The angle iron approach is a simple, quick way to see if the concept works. Probably, it is more important to get a precision fit of the bolt holes than anything else. I drilled the holes slightly undersize, then filed them to fit the exact bolt diameter and spacing.
