Steering wheel removal 1979 MGB
I am trying to remove the steering wheel on my 79 B to replace the turn signal, horn hi/low beams switch. Do you know a way to get the steering wheel off then replace again?
Re: Steering wheel removal 1979 MGB
I don't know about the 79 but my 70 and 74 don't require steering wheel removal to chane the turn signal switch.
Steve |
Same here on '76 you'd just remove the plastic shroud between the steering wheel & dash. I'd think the 79 is the same but not sure.
jbarila John Barilaro Red Sox Nation! (60 posts) Registered: 11/02/2007 08:29AM Main British Car: 1977 MGB Ford 302/5L |
Just remove the cowling and then you can access the turn signal switch.Remove the 2 screws and the clamp...replace your switch. One thing if you decide to remove the wheel anyway DO NOT use the loosen the nut and hit it with a hammer while pulling on the wheel method. This has a very good chance of collapsing the steering column. This is a safety feature for when your body hits the wheel in a crash, the column collapses to absorb some of the force.
Steering wheel removers can be made easily or bought or rented. They are worth it, I collapsed my column and now have an ugly repair to do. |
Jim, you may have to loosen the mounting bolts for the column and allow it to drop a bit to get access to the screws in the cowl. Once those are removed the cowl should split and slide up over the stalks on either side.
