Scott68B Scott Costanzo Columbus, Ohio (561 posts) Registered: 10/25/2007 11:30AM Main British Car: 1968 MGB GM 5.3 LS4 V8 |
Fiberglass & Engine Bay Heat
Does anyone have any negative experiences using fiberglass components in an engine bay? I know nothing about fiberglass at this point but I'm reading that the heat resistance of polyester resin based products is somewhere between 170-210 F. I would guess it wouldn't be unusual to exceed this range on a warm day. Any insight would be welcome.
Thanks! -- Scott |
Re: Fiberglass & Engine Bay Heat
Scott, that sounds a bit low, most resins cure at almost 300 degrees F, I'd think they could withstand well over 210F in use. Everything around the engine in my old Corvette was fiberglass and it never showed any sign of damage from the heat. Some of the "factory" muscle cars in the 70s had fiberglass hoods as well. If you keep it at least an inch away from the exhaust manifold I wouldn't think you would have any problem. You could run it a bit closer if you use some sort of heat barrier or reflector between the two. A piece of aluminum with a 1/2" air gap between it and the body really will help reduce radiant heat transfer.
My fan shroud is made of good old fashioned matt & resin and seems to be holding up just fine......operating in 200F environments isn't a problem.
Scott, The heat distortion for poly parts depends on the type of poly resin used , GP or general purpose resins are in the 160 f range, Isopthalics (the type we use) are in the 225f range more than adequate for the average situation. Now if you want to get really trick, you could use epoxy , however the same can be said for lower grades of epoxy, which are dimensionally stable
but have poor heat distortion, but a good grade of room temp cure epoxy will easily go 300/350 f and makes a much stiffer laminate, the down side of epoxy lams is that the resin is 3 to 4 times more than poly , the reinforcement ( e-glass/carbon/kevlar etc.) costs more and the whole process is more labor intensive ,hence the higher end price. Basically as Bill said, as long as your headers are few inches away you should have no problem. good luck. Dave Craddock |
Everyone, thanks for the responses, it's a big help.
Dave, thank you for the detailed response, exactly what I was looking for. Graham, a radiator shroud is what I'm going to attempt to fabricate. Regards -- Scott |
Scott, a good way to make a rad shroud of fiberglass, is to make it out of mat board(as in picture matting)) ,you can tape it together try to keep it neat looking, then take some johnsons paste wax(or minwax) as in for waxing wood surfaces, wax few coats letting it soak in a little before buffing off the eccess( you can coat with PVA mold release if you have it also) then layup your fiberglass over the cardboard mockup, let it go off thoroughly, then peel the cardboard out from the inside trim as necc. and sand any ugly edges , drill the mount holes and paint. If you want it smooth on the outside do the above on the female side
of the model instead, maybe not the prettiest of parts but should be effective. Dave Craddock |
Using Dave's method (rather than a hard mold, like wood) allows you to design in shroud surfaces that otherwise would result in a part/mold lock issue using conventional mold tooling...and you don't have to worry about a 3 degree taper on the release surfaces.
The down side is that it's good for a one shot part before the mold is destroyed......that's a good trade off for a one off part! |
Sometimes sheet brass works pretty good too and it can be buffed out when you finish. Doesn't have to be one piece either. I made a very nice 4 piece shroud that went together with stainless button head capscrews.
JB |
Scott, I've had my F/G hood installed since 5/05 and driven about 30k miles. The temp surely has been over 225 degrees inside and over 110 on outside. This hood was 1 of 3 original modified MGC types made in Fla. when they became available. There has been no degradation and it is still solid. Don't think there should be a problem with a shroud. Now for the Dickel cupholder! NOTE: only consume Dickel when you return to the Room! Merv will use it for Tim Horton's coffee. Ha
I have ultra thin fiberglass hoods on my race cars and have had no issues. It gets real hot under there. Now an engine fire, that's a different story.
Thanks for the feedback Kelly & Todd, I appreciate it.
Kelly, I shared the last sliver of your Dickel with my neighbor John. He really like it! -- Scott |
