Polycarbonate windows in hardtop
Currently I have a hardtop for my MGB that has glass side and rear windows. I use the car in sprinting the rules do not restrict what I do to the hardtop. My plan is to replace the glass windows with ones that I will make from polycarbonate (perhaps lexan to some of you). The windows will be glued in useing a PU type sealant but I may use some screws as well. The question in my mind is what thickness to use. I have an offcut of 3mm polycarbonate that is big enough to do the 2 small side windows. So my main concern is the rear window. I want to keep the weight down but it needs to be stiff enough not to act like Rolf Harris's wobble board. So anyone know what thickness to go for?
Re: Polycarbonate windows in hardtop
My Parish Plastics hard top uses 1/8" Lexan for the wraparound rear window.
JB |
Thanks Jim.
From the pictures I have seen of the Parish hardtop the back window has alot more curve to it than mine. While my hardtop is not a works one the back window is very similar. |
I know many racers here in the states with a lexan rear window will put aluminum strips to keep them from coming out and make them rigid. Sometimes the strips are required.
