Aerowing extrusions ?
You know-miniturized wing section ? Up to say 2" front to back. Hot-wired structural foam, extruded plastic or aluminum ? Looking for maximum lift to drag ratio. Need to function with hi chord angle change,(articulated). I'm alluding to use as grille work that adds downforce. Thanks, roverman.
Edited 2 time(s). Last edit at 10/27/2011 07:57PM by roverman. |
Re: Aerofoil extrusions ?
Art, not a true air foil, but should give some downforce depending on the angle it's mouted. As usual more angle more downforce and more drag, it's always a trade off. [www.aircraftspruce.com]
That's similar to what I used as supports for my wing. Also, check out the model aircraft suppliers. I'm pretty sure you can buy leading and trailing wing edges and they should be about the right size for your application.
JB |
Re: Aerowing extrusions ?
Art, I think you're wasting your time/energy etc. on that one , a front air dam will produce more downforce easier
like Dave Townsend did on his B(check his posts). Dave Craddock |
Dave, take a look at the drawing of what Art is planning, [forum.britishv8.org] the radiator will be in the rear between the tail lights. The aero effect he wants would add downforce in the rear, hopefully making a higher mounted wing unnecessary.
Don't know of anyone with a front air dam to fit a Jensen Healey do you? Edited 1 time(s). Last edit at 10/28/2011 12:10PM by Bill Young. |
Clan, Huffaker and Delta both do. I will run "somethig" on the front, including perhaps an air inlet to oil cooler and brakes,(former turnsignal surrounds). Cheers, roverman.
Rear rad, good idea,how are you ducting air in to the engine compartment /rad??
BTW; we did an scca f-prod jensen healy body kit for a customer he ended up broke from the stock market and I ended up with the moulds, they were pretty radical for a production car(pushing the rules). Unfortunately I have no pictures of the completed model but if you're interested I'll take shots of the tooling. Dave Craddock |
Art, I found some pics(Iknew I had some!)fender models are done and we were developing the front air dam assy,
rear wheel arch development, as you can see our plan was to allow the pumping air from the tires to exit out the rear of the fenders, from the side the wheel arch appeared the same as the stock wheel arch, the fenders covering 120degrees of the tire from the top. Dave Craddock |
Dave,
What would it take to produce a set of those flares? Thanks Fred |
Re: Aerowing extrusions ? Still need.
Or Dave....maybe (2) sets ? Nose of car will be very similar to David Townsends' "photoshop".I'm not sure the engine needs air, just coolant. The hood will get hot air exits as needed, "maybe" a Hemi "shaker", oem. scoop/ backwards ? Air to rear radiator= "Kamback"/low pressure area, powerful fans, belly pan and "maybe" diffusers to air inlet. How much track width over stock ? Fred, I'm thinkin-your scheemin for a 32 valve JH ?? Jensen Healey's are kind of the "Edsels" of this forum. Let's change that ! Cheers, roverman.
Edited 2 time(s). Last edit at 10/31/2011 11:31AM by roverman. |
PM sent you'se guys.
Dave |
