Re: Dipped MGB V8
I can see where that would be very useful, especially if you aren't finished with your body mods just yet. Wonder how a fresh application would blend with an older layer?
Re: Dipped MGB V8
It looks great in the pics. I've seen a few plastic-dipped cars at shows and some are pretty impressive. Hadn't thought about repairability, can it be blended if needed?
Re: Dipped MGB V8
It can be blended pretty easilly and once youv'e done your 1st dip a color change is just a few hours of work as you cna spray 3 or 4 dips over your 1st one before peeling. The one thing I have found is that there aren't any do overs. I peeled and re-dipped my hood because of some perceived striping in certain light. It came out perfect until the 2nd coat of the 50/50 clear/anthracite where I got a sag. There is quite a learning curve on spraying clear. haven't found a way to fix it since you cant just sand and respray.
I am really starting to like the look and new wild colors are coming out every day including some crazy color changing pearls. What I have realized though is that after several months of work, I still only have my MGBs body about 90% perfect. Even dip don't cover that! :). I am starting to look at this as a part time business so the MGB V8 may become my mule for testing and learning the craft. Kind of an expensive mule.... |
Re: Dipped MGB V8
If you have any interest in this, check out this video of a dipped color changing Porsche. The finished product starts at about 2:20 on the video. Crazy!
[www.youtube.com] |
Re: Dipped MGB V8
This is the way I am going to do my car. I love this idea, Low cost, changablity, and gives you an idea of paint colors and look of your car. I am like you, I want a good paint job but it will take years to save the money for the paint job I want, and when you talk about how much it cost I want to make sure I love the color. I recently used it do the wheels on my wifes jeep, and was really easy and only cost about 10.00 for four tires, not to metion totaly reversable. Just to give her car a different look. So many ideas and so many possibilities.
Re: Dipped MGB V8
Im with you Nick. This started out as a cheap way to "finish" my car as I was out of money but now its gotten kind of addictive. New colors seem to come out daily.
So many dip colors so few cars. FYI, I am having trouble spraying the gloss/anthracite mix. I love the richness of the satin color but out of 3 panels I have sprayed, only 1 has been perfect with no sags and these panels have been laying horizontal when i dipped them. My dips have been perfect until I spray the gloss/base mix, then i get into trouble. The gloss is runny stuff, thinner than most clear coats. My suggestion is to stick with the matte until you get good. |
Re: Dipped MGB V8
I don't get it,,, if you are planning to paint your car with normal automotive paints, you would have to remove all the rubberized substrate, if it only lasts 3 years what actually happens to the stuff as it ages ? this seems more like something you would put on lawn furniture,,, please advise.
Dave |
Re: Dipped MGB V8
The stripes do set it off nicely and the matte finish looks good. It will be interesting to see how it weathers.
Re: Dipped MGB V8
I will probably never paint a car again with base coat clear coat. Its just too expensive and with all of the cool color changing pearls coming out in dip, I cant see going back to $5000 to $10000 dollar paint jobs when I can change my car color every 3 months for a hundred bucks or so.
As Jim noted, durability is an issue with dip. It only lasts a couple of years with good care. Most guys change their car color like they change their undies so who cares about durability! :) I am going to get the bodywork professionally finished and then dip her again in Sazuka blue pearl this spring, then maybe burnt copper for the summer and then.... |
Re: Dipped MGB V8
Keith, You like,I like. Like Jim stated the red stripes make it. I have done some DIP on some formed plastic panels I have placed in front of the radiator and the slam panel. I will be doing some of the carbon fiber look-a-like soon.
charles panels after dip panels before dip on car panels after dip on car |
Re: Dipped MGB V8
Re: Dipped MGB V8
I take it the dip strips off the wheels with no trouble?
Re: Dipped MGB V8
Yes, it just peels off if applied correctly. I peeled my hood twice as I was learning to spray the stuff. You can also do 2 to 3 color changes before you need to peel.
It primarily appeals to the 18 to 35 crowd because its fairly inexpensive. Some view it as an accessory of sorts, like a mobile device cover, something ti be changed often. I believe it will be the next big thing in exterior automotive treatments. I've seen the colors and interest explode in the 3 months Iv'e been fooling with it. The President of Dipyourcar is a genius at social media and youtube marketing. Probably more info than you were looking for. :) |
Re: Dipped MGB V8
Yeah. I meant to say "tires". :-)
