tachometer/speedometer opinion
I am to the stage of deciding what to do about my tachometer and speedo. I talked with Morris at West Valley, and the speedometer change to electronic is somewhat expensive. I had thought about a Cable-X or similar, but cannot tell if the Triumph cable would match the GM/Ford output. (tech guy there said probably no, since it is European, and therefore metric). I am thinking it might be easier to go with new gauges that closely match the existing. I have a Tremec T-5 from an '88 Mustang, and I do have the VSS for the trans. I will also be using a Megasquirt, either alone, or with a Ford EDIS. I would value any wisdom you might offer.
Thanks, Dennis |
Re: tachometer/speedometer opinion
My opinion would be electronic.
You already have the VSS and the electronic speedo is far easier to calibrate. Especially if you plan to play with tire sizes and gear ratios. Live like you mean it. Fred |
Dennis, I don't know if you're trying to maintain a stock look or not, but something to think about. I tried cable, then electric, and finally ended up with a GPS speedometer from Speed-Hut, yes, a little more expensive, but they will give you much more information than just speed. You can make any changes you want to the drive line and the speedometer couldn't care less. Given that, I agree with Fred and Curtis, I would go with electric too.
Paul |
X2 on what Paul said.
I haven't uses a proper GPS driven Speedometer, yet; just the speed readout on a GPS (Garmin). I'm planning on GPS drive for my 'B for the very reasons he mentioned. If you choose to drive it with a VSS, make sure the speedometer you choose is, in fact, easy to adjust. Some I've found require either gauge removal from the dash, or going under the dash (don't buy one where the adjustment is on the back of the speedometer, less common today, but good to be aware of). If you decide on a speedometer that doesn't offer GPS drive, and decide you want that, there is at least one company out there that offers a GPS drive unit. Good luck. ): |
Thanks for the information everyone, just what I needed! I am going to electronic for both gauges, and will consider a GPS speedo if the VSS turns out to be too much trouble. I need to roll under the car and look at space that is available for the VSS without hitting the transmission tunnel. If there is just a small interference, I can fab. a cover for the protrusion, otherwise, GPS it is!
Thanks again! Dennis |
Dennis, I have 3.4L V6 with T5 from a Camaro. I went with VDO gauges then I find that the tach. does not work. I scope and measure, then talk with VDO support. I am told VDO tach signal needs to ride on 4 plus volt base, I have less than 0.05 volt base. Point I am making is "get the facts, just the facts".
After over twenty years of service, my VDO digital speedometer died yesterday with a puff of acrid smoke. I've just ordered an Auto Meter (part# 2489) to replace it. I liked the VDO's motorized odometer better than the modern LCD, but otherwise the Auto Meter's styling will match my car better.
I sent my TR6 speedometer and tachometer to Red Line Gauges in California and they put VDO internals in the tachometer and Autometer internals in the speedometer.
I liked what they did as these gauges look close to stock. |
Better gauges out there I'm sure, but the only electronic speedometer I tried was a "Shark" from Dolphin. I had a bit of an issue with electronic interference from who knows where, the speedometer read 5 mph at idle and with the least throttle input read a constant 140, this with the car setting still. Before I got it figured out I fell in love with GPS.
Paul |
primaz Alan P Northern California (15 posts) Registered: 05/26/2014 10:43PM Main British Car: 1965 Jaguar 3.8S LS V8 5.3 liter aluminum block/heads |
If you are putting a modern V8 into an old car like I did in my Jaguar 3.8s with a modern LS1 V8 you can use this device to retain the old school gauges with the modern engine that assumes a digital gauge.
[www.dakotadigital.com] This takes the electronic and turns it into a rotating cable like the factory gauges. |
Looks like a nice bit of kit but at $300 a bit spendy.
Jim,
I searched pretty extensively and this was the only thing that I could find to keep your classic gauges yet interface with a modern electric engine/etc. For my Jaguar I wanted to keep that classic stock look. Yes it is a little pricey but before that was available another company said they would create a similar device but actually anticipated the price to be more like $600 so for $299 it is better than putting non classic gauges IMO I did add LED bulbs to the stock gauges and added a blue LED that is manually controlled for an interior light. |
Some engine controllers (MS-II for instance) have auxiliary outputs that you can define for PWM and use to drive a small DC motor. In a few cases a stepper drive is also a possibility.
Carl,
My gauges are all stock. What I did was to replace the Jag bulbs to LED bulbs. What I also did was install a blue LED strip under the wood upper part of the dash that is tied to the interior lamp toggle switch. I added that Dakoda digital box that converts the modern LS engine output back to old school rotating cable input so that I can keep all the gauges stock. |
maxwedge5281 larry ingram south carolina (52 posts) Registered: 09/23/2014 05:59AM Main British Car: 59 bn6 zz4 sbc 200 4R aod, 59bn6 302 ford, tremec |
i used speedhut gauges in my v8 healey. mi especially like the combo gps speedometer with gas gauge inset. the fuel level is programmable to match up with the fuel sender in the tank. there are lots of combination colors, dials, fonts, bezels, backlighting, etc.
Edited 1 time(s). Last edit at 12/06/2015 08:31PM by maxwedge5281. |
ToyBug Dan Wilson Colorado Springs (14 posts) Registered: 06/01/2010 10:09PM Main British Car: 1959 Bugeye Sprite, 50's MG Special Toyota 2-TC 1600cc, MGB 1800 |
Has anyone installed a gps driven speedo AND nav system? On my MG Special (see Project Journals), I figure the easeist way out is a gps driven speedo, and wonder if once you have the gps antenna/sending unit, is there a nav system that is intended to be installed in dash, and not stuck on with suction cups (they do suck, however if they were meant to stick, they would be called stiction cups), or velcro, duct tape, etc. What about sourcing a nav system from a wrecking yard? Any thoughts?
Thanks, Dan Wilson Colorado Springs |
