MGB body reinforcements for IRS?
Hi everyone,
I've read a lot about useful reinforcements of the MGB unibody frame when retaining rear leaf springs on a V8 conversion, but I haven't seen much discussion about reinforcements needed when using an IRS setup. I'm planning to use a bolt-on Hoyle IRS assembly, which uses many of the factory rear suspension mounting points. However, I expect the stresses on the frame will be applied to different points, given the changed geometry. Anyone out there have experienced to share? Dave |
Re: MGB body reinforcements for IRS?
On the Jag conversions I used a member which tied the two front spring hangers together and in the center butted up against the lip on the panel that forms the bottom of the driveshaft loop using a 1/4" thick nylon wear strip to handle thrust loads.
