exfed12825 Tony Gentile Waterford, Pa (61 posts) Registered: 03/30/2016 02:43PM Main British Car: 1974 MGB 347ci Bessel Motorsports/ Ford stroker 530 hp |
Lets Talk More About Windshields
Okay, what is the trick to getting the windshield and frame lined up and back on the car. I read somewhere that a piece of 1/4 rope in the flap will help you pull the flap out flat. So I did that but that isn't the problem I'm having now. I can get the bolts closest to the pillar in but then I can't even get close with the two on the end of those ears. I tried putting the bolts in the center post and they pulled the pillars farther away from lining up
Re: Lets Talk More About Windshields
I used a bunch of ratchet straps.
If I remember right, I got the bottom two bolts in and then levered the windshield/frame forward to get the upper tao to line up. Best done with a couple of people so you dont put excessive twisting force on it.
x2 on people helping to push down, and I found that without an air ratchet I don't think I would have got them to start once it was close.
DiDueColpi Fred Key West coast - Canada (1364 posts) Registered: 05/14/2010 03:06AM Main British Car: I really thought that I'd be an action figure by now! |
Make sure that the rubber is warm. A really hot day or a hair dryer work well (no heat gun unless you are very skilled with it)
And coat it all with liquid dish soap so that it can move. |
You can also sweat on it a lot, that helps too.
Could you please post it here Jim? It would be good to have that resource available to all.
Moderator Curtis Jacobson Portland Oregon (4575 posts) Registered: 10/12/2007 02:16AM Main British Car: 71 MGBGT, Buick 215 |
Notice: I've extracted Jim Durham's post with killer MGB-roadster specific tip and photo to its own thread, and I've made that new thread a "sticky". I'll leave this thread open for other/general windshield related tips.
Thanks Curtis. I hope my post helps a fraction as much as the info. on this site has helped me.
