maxwedge5281 larry ingram south carolina (52 posts) Registered: 09/23/2014 05:59AM Main British Car: 59 bn6 zz4 sbc 200 4R aod, 59bn6 302 ford, tremec |
lucas three position switch
with the help of this forum I installed two speed wipers into my 1959 bn6 healey. currently I use a on-off-on toggle switch that does not match the usual healey dash. does lucas make a switch that would use the original wiper slip on pull handle? any help is appreciated. it is the toggle switch lower left corner of the dash....looking for a switch that will use the same type pull as directly above it.
Edited 1 time(s). Last edit at 08/15/2018 10:31AM by maxwedge5281. |
Re: lucas three position switch
There are 3 position Lucas pull switches out there...typically used for headlights.
[www.autoelectricalspares.co.uk] Edited 1 time(s). Last edit at 08/15/2018 06:45PM by ex-tyke. |
Off, Dim and Flicker positions. But seriously, it looks like Vicky has it. [www.victoriabritish.com]
