Wrong flasher can run battery down
Date: March 04, 2018 07:25PM
My MGB with AA wiring uses a 3 post flasher unit for both the turn signals and the hazard. I had an issue with the battery draining over time and eventually tracked it down to the flasher unit. There are now a bunch of 3 post flashers available. I was using one that had "35" in the number and had a 36 in the turn signal circuit. The hazard circuit showed a 200 ohm resistance when switched off and with the fuse pulled. That's a continuous 65ma drain and will ded the battery over a week or so of unuse. Switching the flasher to the 36 fixed it.
I may have got the numbers backwards. If you have this problem just pull the fuse and check for voltage across it. If there is, you can check resistance on the load side to ground, it should be infinite.
Re: Wrong flasher can run battery down
Date: March 05, 2018 11:29PM
Interesting Jim. I'm going to check mine.
Rebrean
James Russell
(1 posts)
05/30/2021 09:15AM
Posted by: Rebrean
Date: May 30, 2021 09:18AM
Thanks for the advice! Batteries can fail for various reasons, such as inaccurate float charge voltage, loose inter-cell links or connections, loss of electrolyte and high and uneven temperatures, as well as aging and lack of maintenance. The cycle life of Li-ion batteries is affected significantly by the depth of discharge. The depth of discharge is the amount of a battery's storage capacity that is utilized. I found out about all these things while browsing https://batterytools.net/ where there are a lot of articles related to batteries.
Edited 1 time(s). Last edit at 05/31/2021 01:24AM by Rebrean.
Jim Stabe
Jim Stabe
San Diego, Ca
(829 posts)
02/28/2009 10:01AM
Posted by: Jim Stabe
Date: May 30, 2021 11:15AM
Maybe I'm just noticing but what's up with the new wheels in your avatar picture?
Date: May 31, 2021 08:54AM
I anodized them
