A sticky mess!
I normally do my upholstery in leather, but recently did up a 65 Volvo for my daughter. We used a nice tan vinyl for it and for the most part it turned out fantastic.
However all of the trim pieces are garbage. All of the vinyl that is glued down to metal has let go in the heat of summer. We see 35 to 40 degrees C in BC in the summer . The 3M contact cement has turned into an oily goo. Any ideas? We've redone them twice and they are fine until it gets hot. |
Re: A sticky mess!
Are you using the water based contact cement? I've always found the old standby Weldwood solvent based contact cement to be a good choice.
Re: A sticky mess!
What a pain.
Woolies have a high temperature glue that I used 12 years ago to stick carpet inside the hardtop of my Land Rover. Good for 100C they say. It's a contact, so not the easiest for fiddly stuff. Perhaps they'd ship it over, they ship worldwide. [www.woolies-trim.co.uk] Ivor |
Re: A sticky mess!
Yep, good old solvent based contact cement Jim. Even the weldwood gums up with this material. When it happens everything feels oily. Might just be the type of vinyl?
I see that I can get that glue on ebay Ivor. I'll give it a try and let you know. |
Re: A sticky mess!
There was a Bostik 2 part contact cement that we used on our Avon whitewater boats (fully calendared and vulcanized silicon/fabric matrix) Shelf life of only one year but the best contact cement I've ever seen. It had to be to withstand the rapids. Put the Weldwood way WAY in the shade. I looked it up, it's Bostik 2402.
[ibsparts.co.uk] Not exactly cheap but very very good. Jim |
Re: A sticky mess!
Fred, Your vinyl maybe PVC instead.You could try PVC pipe glue. I have a recliner chair that looks like vinyl/leather but is actually PVC.
Re: A sticky mess!
We used a different adhesive for the PVC boats when they came out. It used MEK as a solvent, which is very nasty stuff indeed. You want to avoid breathing it, it'll ruin you.
