Electric tach fubar
So the second electric tach is fubar.
Needle jumps around, then when I go over 2000 it jumps to max and stays there. I recall the same happened to the tach in my previous vehicle. The common factor is that it had a Lumenition Optronic (optical) electronic ignition, and the tach was hooked to the coil. I wonder if there is a problem with the spark plugs affecting the ignition - no other sign of that - or upsetting the tach. Should I change to resistor plugs, or perhaps just on the left bank where the ignition and coil are located, or is it just one of those things... Ivor |
Re: Electric tach fubar
Have you considered using Theo Smit's tach movement driver circuit?
Quote: Yes, I'd try resistor plugs. And I'd recommend using the exact same model spark plug for each cylinder. |
Thankyou.
Theo Smit I guess is here. No haven't encountered that... electrikery... likely beyond my pay grade. I bought a Faria tach now, then realised I need to find a way to podmount it as no one makes a 110mm pod for a 4" tach, sigh... V8 |
I usually just gut the old gauge and mount the new one inside it.
Eight new resistor plugs BPR5ES. On a drive today, only 15 miles but still... the tach was OK.
So maybe it was interference with the ignition module. In which case I have a spare 4" tach :{ I found that NGK are now offering solid-top plugs, meaning the little wotsits don't unscrew. This is good, unless one is running a vintage, as I have several times found a misfire due to the wotsits undoing themselves, and had to affix them with threadlock. Not all progress is bad. |
When installing new spark plugs, I always put a wrench on them & tighten the top nice & snug with pliers. Never had one loosen up. They sometimes are loose out of the box.
The solid top version of the BPR5ES is part # NGK4006. |
